FS: Tanable Ypipe
FS: Tanable Ypipe
FS is a Tanable Ypipe used for <2mths on a weekend car.
Got it new for north of $500 USD shipped to my doors:
http://www.mynismo.com/products/?id=2952
I am asking for $290, OBO, local pickup in Toronto only
There is nothing wrong with this ypipe at all, I am going into a setup that will eliminate the need of a traditional Y.
See below if you want to learn more about why I went with Tanable:
Tanable merge collector:
2.75" ID instead of 3" in most afteramarket Y (which is too large for OEM midpipe)
OEM merge collector, notice the design (use of cast iron crush collector) and quality of weld:
It is made in Japapn!
This was more of a performance mod that will allow you to start modding from the front to the back; always remember that you should start from the front to the back (not the other way round), and the ypipe is as front as you can go unless if you are touching cats/ headers.
For performance, I didn't do any dyno after this mod, so I cannot tell you any absolute #s. However, I do feel better pull above 4k rpm and a deeper sound throughout the RPM.
Another reason that I went with this was that this pipe was a good 7+ lbs lighter than the oem pipe =)
Hope this helps
Replied to all pms, but sorry, I do not consider any trades.
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
