Spc upper control arms $225 orlando
Old Jul 15, 2009 | 02:03 AM
Boostwhore's Avatar
sold thanks
Old Jul 15, 2009 | 03:46 PM
Boostwhore's Avatar
bump
Old Jul 15, 2009 | 03:57 PM
04G35NYC's Avatar
Pictures please.
Old Jul 15, 2009 | 06:03 PM
parhamm1's Avatar
Give me a good deal on both the coils and the SPC A arms shipped to 28117...
Old Jul 15, 2009 | 09:39 PM
crashnburn's Avatar
how much picked up?
Old Jul 16, 2009 | 05:35 PM
Boostwhore's Avatar
Old Jul 16, 2009 | 11:05 PM
crashnburn's Avatar
firm on price?
Old Jul 17, 2009 | 03:02 PM
kenasaki's Avatar
comes with everything needed right?
Old Jul 18, 2009 | 01:21 AM
Boostwhore's Avatar
for the most part the longer they sit I will come off the price. Theres nothing needed for install you use a metal cone shaped piece off your factory ones very straight forward. no clunking etc. Makes the car look so much better and saves tires. There 400 new
Old Jul 18, 2009 | 01:40 AM
G SEDAN's Avatar
where are the shim kits?
Old Jul 18, 2009 | 10:54 AM
Boostwhore's Avatar
i have no clue where I put them I will have to look for them i had no need to install them
Old Jul 18, 2009 | 09:58 PM
crashnburn's Avatar
well after installing my teins yesterday, i think ill need these but have a clunking in front passenger side that has to be fixed first... will have it looked at monday so ill let u know asap
Old Jul 19, 2009 | 12:55 PM
Boostwhore's Avatar
I bet your swaybar endlink isnt tight all the way
Old Jul 19, 2009 | 03:02 PM
G SEDAN's Avatar
you should disclose that the shim kits are missing in this kit. Without it, the adjustments on it are very limited. Just because you didnt need it, does not mean others won't. I'm dumped and my camber was almost -4 degrees, you can't get it back in spec with just the a-arms.
Old Jul 19, 2009 | 04:31 PM
crashnburn's Avatar
my sway bar links are good... its 1 of 3 joints in there... probably compression rod
