FS: HKS F-Con PRO Engine Management for G35 / 350Z (So Cal)
Old Jul 22, 2009 | 08:07 PM
AMS MIKE's Avatar
This came off my friends 2004 G35. He sold the car awhile ago and this has been sitting around.
HKS Fcon VPRO ECU v3.2.4 with complete Plug N Play Harness.
Fits: G35 and 350Z
slightly used. 9/10 perfect condition. I would say its 10/10 if it was still new in the box.
SOLD
The HKS F-CON V Pro is a fully featured standalone engine management system that connects as easily as a "piggy-back" fuel and timing controller. As modifications to a vehicle are made, the need for fuel and timing adjustments becomes critical for performance and safety. The F-CON V Pro with its 32x32 resolution for both fuel and timing maps is the optimal solution. The F-CON V Pro can control up to eight injectors and D Jetro or L Jetro setups. --- Injectors can be set to fire as batch, sequentially or staged. The F-CON V Pro can also read drive by wire vehicles. Programming is done via the HKS Power Writer software; which only Certified HKS Pro Dealers have access to. The HKS Power Writer software for the F-CON V Pro has some very unique abilities to simplify setup and tuning. Via the vehicle start up menus most Japanese import cars can be easily started by selecting the vehicle’s parameters (Make, Model, Engine and etc). Tuning is simplified due to the A/F Feedback control; where a target A/F value can be input and the F-CON V Pro will adjust fuel automatically. Also full data logging capabilities are built into the F-Con V Pro Power Writer software. All major vehicle conditions including; speed, rpm, water temperature, intake temperature, timing, boost, injector duty cycle and etc can be logged to an HKS Pro Dealer’s computer.
Old Jul 22, 2009 | 08:13 PM
AMS MIKE's Avatar
If you need references, I have thousands. just ask
Old Jul 24, 2009 | 04:53 PM
AMS MIKE's Avatar
Old Jul 26, 2009 | 01:32 AM
AMS MIKE's Avatar
Bump for an amazing stand alone ecu!
Old Jul 27, 2009 | 03:24 AM
sushiboiiii's Avatar
bump for a dope ecu!
Old Aug 5, 2009 | 05:28 PM
AMS MIKE's Avatar
Thanks
Old Aug 5, 2009 | 09:21 PM
EGGPLANT's Avatar
Bump for what i wish i could use.. lol.. no FI..
Old Aug 6, 2009 | 03:54 PM
AMS MIKE's Avatar
T t t
Old Aug 9, 2009 | 12:42 PM
AMS MIKE's Avatar
Bump for a badazz ecu!
Old Aug 14, 2009 | 03:03 AM
AMS MIKE's Avatar
B u m p
Old Aug 20, 2009 | 07:42 AM
Nico's Avatar
PM sent.
Old Aug 21, 2009 | 12:17 PM
AMS MIKE's Avatar
Originally Posted by Nico
PM sent.
Replied.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
