FS: Ichiba front camber kit
Old Aug 26, 2009 | 01:19 AM
bigdano's Avatar
in process contacting seller... bushing missing and kit useless without bushing.
Old Sep 3, 2009 | 09:09 PM
thatoneguy's Avatar
Ok, so you go to Pay Pal and you file a claim. Then you go back and edit your posts. All the parts are there. And you had my phone number the whole time and not once called me about anything.
Old Sep 3, 2009 | 09:24 PM
thatoneguy's Avatar
And the only bushing that is missing from there is the one on the EXTRA bracket I gave you with the kit. Nothing else is missing from there and you can even see that in the picture YOU took of the kit when you got it. Everything is there. I don't know what you're trying to pull here man but knock it off and give me the money back.
Old Sep 4, 2009 | 12:22 AM
Shrummi's Avatar
Originally Posted by djosephm
OK I need some help here... thatonedude sold me this and it just arrived. He didn't put one piece of packaging material in there so the pieces were rattling against eachother losing paint. In addition, he didn't include all the parts. What do I do?
there are bushings installed on the two brackets and then an extra bracket and an extra bushing what's the problem here?
Old Sep 4, 2009 | 02:05 AM
loki05's Avatar
all pieces are there...... do you not know what a camber kit looks like?!?
I have this exact camber kit.
there is 2 brackets with 6 bolts each.. which is correct. it also has the bushing on both brackets.
and there is also an extra bracket which is not needed.
the only thing that could possibly be missing is the pins.
which you can use your stock.....
so I do not see a problem here........
socalg35x
Aug 7, 2015 09:36 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
nascarbuff17
Jul 16, 2015 10:23 AM
djreinx
Jul 13, 2015 05:04 PM
