WTB: HELP!!! Need stock plenum bolts... but where?
Old Feb 9, 2010 | 09:04 PM
bigdano's Avatar
Guys I need a set of stock plenum bolts.. I already took out my spacer and now my upper plenum is just sitting there waiting to be bolted down. Does anybody know where I can get a set of bolts or does anybody wanna hook me up?
Please help me out I can't drive til' I get these bolts!
Dan
Old Feb 9, 2010 | 10:12 PM
Rambo's Avatar
try a dealer. Should not be to expensive.
Old Feb 9, 2010 | 10:59 PM
smokincoupe's Avatar
i need the same bolts someone help us out
Old Feb 10, 2010 | 12:06 AM
SxExCx's Avatar
go to any autoparts store. You need to count how many of each (3) lengths of M6 bolts and just buy singles. It should cost $10-15.
Old Feb 10, 2010 | 11:16 AM
blueG1's Avatar
hey guys, does anyone know what bolt i need to install a 5/16 motordyne spacer besides the ones they sell....
Old Feb 10, 2010 | 03:04 PM
bigc's Avatar
Wings Nation
you can get the bolts from any decent hardware store. i copied the stuff below from a thread i made over on my350z.com.
Originally Posted by - bigc -
There are a bunch of threads on here asking for the sizes of the OEM plenum nuts & bolts. There's some info in the FSM, but, surprisingly, even Nissan's fast system doesn't have the complete specs. Anyway, the OEM sizes are below - add 8-10mm if you're running a 5/16" plenum spacer.
Intake Manifold Collector (Upper)
Bolts 1, 3, 6, & 9 = M6 x 1 x 60mm (red)
Bolts 2, 4, & 5 = M6 x 1 x 45mm (yellow)
Bolts 7, 8, 10, 11, 13 - 16, & 18 = M6 x 1 x 25mm (green)
Nuts 12 & 17 = M6 (green; these nuts & studs are sometimes replaced with M6 x 1 x 25mm bolts in aftermarket applications)
Intake Manifold Collector (Lower)
Bolts 1-6 = M6 x 1 x 70mm (blue)
Nuts 7 & 8 = M6 (violet)
hopefully this helps someone who wants to go back to stock, but has misplaced their OEM bolts.
Old Feb 10, 2010 | 03:05 PM
bigc's Avatar
Wings Nation
the motordyne install guide lists the sizes of the bolts you'll need. you can pick them up from a local hardware store that carries longer metric bolts.
Old Feb 10, 2010 | 03:42 PM
LightsOut's Avatar
SIETESG
motordyne website has oem bolts.
thanks bigc wonderful help
Old Feb 10, 2010 | 05:41 PM
bigdano's Avatar
Omg thank you all!!!
Freeman186
Sep 6, 2023 10:07 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
Raven7
Aug 14, 2015 04:40 PM
