DIY: dual ac button
Old Apr 6, 2008 | 02:58 AM
JOKER's Avatar
CLUB MODERATOR
^what is it for?
What do you need dual ac button for?
Old Apr 6, 2008 | 10:30 AM
simpson's Avatar
Originally Posted by JOKER
^what is it for?
are you for real? the jdm dd finisher plate does not come with the dual ac button. so you take it off the old ac controler and put it on the new one. the button lets you have heat blastin for your girl on her side and the ac coolin your *** down cause she has it so f...in hot in the car
Old Apr 6, 2008 | 02:28 PM
JOKER's Avatar
CLUB MODERATOR
never ran into such issue
Old May 15, 2008 | 10:34 PM
Dan_K's Avatar
Originally Posted by Gilley
Nice work. This DIY is for the 05-07 boards. The 03-04 boards are similar, but a little different.
Also, with the 05-07 boards, you also need to desolder and resolder the LED for the dual button if you want it to work. The LED is already on the board for 03-04.
These DIY's need to be stickied.
How is the 03-04 different? With the 03-04 don't you also need to de-solder a resistor as well?
Old May 16, 2008 | 03:54 AM
lmSteveO's Avatar
Just to clear everything up, the only reason that you would have to do this MOD is because when you change out the HU the AC control is tired into the factory HU so you cant take it out and put it on the new kit. So there for you need to buy a new AC control. Metra makes everything built in but it only for 03-04 HU's and still doesnt come with the DUAL BOTTON. The aftermarket AC control from Metra and JDM dont come with the DUAL BOTTON so if you want that function you would have to take the DUAL BOTTON off the factory HU and put it on the aftermarket one as what Gilley is showing you in this DYI
Old May 23, 2008 | 09:38 AM
heftylefty58's Avatar
Thanks for the clarification SteveO--you answered what I was too afraid to ask.
Old Jun 4, 2008 | 11:46 PM
Beebo's Avatar
Thanks.
Old Jun 19, 2008 | 01:16 PM
dreamweaver's Avatar
this is a great write up... but im curious as to the LED on the old board? will this too transfer to the new board? I see a resistor and a led pad unpopulated? anyonyone know what transfers ot the resistor value of the missing location on the JDM board>???
Old Sep 16, 2008 | 12:50 AM
Dominican1NYC's Avatar
Thanks for this great DIY, just had a quick question. I don't have a soldering iron & was thinking of buying this one to do this project, will this work?
http://www.lowes.com/lowes/lkn?actio...HPK&lpage=none
Thanks
Old Sep 16, 2008 | 04:14 PM
lancer's Avatar
Thanks for the writeup, I agree, that was definitely way overdue.
I'll be doing the same thing on an 03-04 board so it seems like I should definitely do a DIY on that as well... just in case there are some minor differences.
Old May 13, 2009 | 10:05 PM
thescreensavers's Avatar
Mr.202?
Also, make sure you use a static free surface if your going to work on electronics. Static = Death for Electronics.
Old Jul 6, 2009 | 04:27 PM
Airsoft Andy's Avatar
Hi guys. Has anyone done the DD conversion to a Japanese imported Skyline 350GT?
Old Oct 26, 2010 | 12:05 PM
g3fly's Avatar
Did anyone ever do a write up for the 03-04?
Old Jan 5, 2012 | 07:37 PM
  #30
DaGdriver's Avatar
Thanks bro!
