need the performance alternator???
Old Sep 17, 2009 | 07:09 PM
m3vegas's Avatar
hey guys need the performance alternator but dont no how i could make it work on my car because of that fuse thats on the battery terminal..is there any way i could bi -pass that...open for suggestion..
Old Sep 21, 2009 | 02:12 PM
pfarmer's Avatar
What year car and which fuse? Are you speaking of the fusible link. If so keep in mind that you may need to upgrade the wiring from the alternator if it is undersized for the application. Many alternators are actually capable of putting out more than what they are rated for, one value often tossed around is a 30% overcurrent capability. I think that may fit here as for example on an 07 and up it appears tha the fusible link is 140 amps with a 110 amp alternator. If this holds up than a typical 150 amp alternator would need a consideration of wiring, etc. of about 195 amps.
It also depends on why you are putting on a performance alternator. If you are adding an audio system which is one common reason then you may want to look at a dual output alternator and set up a second system for the audio and leave the other as is.
Old Sep 22, 2009 | 03:13 AM
m3vegas's Avatar
daul output as in to power screws .yea i was talkin about the fuseable link but you can bipass an go directly to the battery.i was thinkin of goin wit a 200 amp alternator an yea i was gonna upgrade the power and grounds
Old Sep 22, 2009 | 03:46 AM
pfarmer's Avatar
You didn't mention your year from what I see. Also don't bypass a fusible link without replacing it with another they are there for a reason.
If a 2007 or above keep in mind that your negative battery lead has a current sensor.
Old Sep 22, 2009 | 04:57 PM
m3vegas's Avatar
i actually have a 2003 coupe ,but the fusible link on my car is separate form the alternator plug in.the alternator connects to the fusible link so im just gonna put it on the side of the battery.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Video Share
Jan 31, 2017 04:00 PM
prinny
Nov 22, 2015 11:07 PM
BradMD_96
Oct 6, 2015 09:31 AM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
