I've searched and searched.can I use my MP3 player with BOSE 2003?
Old Jun 27, 2006 | 09:32 AM
tkman00's Avatar
Originally Posted by 350Zed
I believe I have the same head-unit as you, and I contacted P.A.C. to confirm which convertor to use.
Here's my email...
Can you recommend what product I need to purchase to give me an AUX input (RCAs or 3.5mm mini-plug) for Canadian-spec '06 Infiniti G35 Sedan factory BOSE?
It does not have a SAT button. It has a 6-disc in-dash CD changer with CD, Radio, PTY/CAT, and DISP buttons.
Here's their reply...
I would use an AAI – NIS2 and an iC – RCA cable. This will charge the iPod as well as give you good audio sound.
Sam Grove
P.A.C.
(800) 854 - 3133
www.pac-audio.com
I'm going to order the PAC AAI-NIS2 from one of their distributors and see if it works.
not to burst your bubble, but i don't think it will work. the aux-niss, however, I know will work. i got it working just before i was a retard and shorted out the hvac circuit board.
Old Jun 27, 2006 | 10:29 AM
350Zed's Avatar
These guys at PAC would sell more of these things if they knew what part works with what car...
Do you have the AUX-NISS or AUX-NISSv2? What stereo do you have? Can you post a pic of it so I can see if it's the same head-unit as my '06 BOSE?
Old Jun 27, 2006 | 11:22 AM
tkman00's Avatar
oh, u have an 06? :P you should be fine then. this thread was for 03 bose w/o sat button
Old Jun 27, 2006 | 11:31 AM
350Zed's Avatar
I'm not so sure... there's no SAT button on my '06 BOSE HU. I've asked PAC to double-check their specs for me.
Old Jun 27, 2006 | 11:43 AM
350Zed's Avatar
New info from PAC:
Use the AAI – Nis2 and not the iC – RCA cable if you do not have an iPod. Our instruction indicate hoe to operate a radio without SAT and with a radio button. As far as I am aware ALL G35 radios are SAT capable weather you purchased at the dealer or not. Here is a link to our instructions.
http://pac-audio.com/instructio<wbr>ns/instructions.asp?mmSearch<wbr>=AAI-NIS2
Old Jun 27, 2006 | 09:32 PM
tkman00's Avatar
you should have a SAT button i think, 03s were *not* SAT capable
Old Jun 28, 2006 | 07:35 AM
350Zed's Avatar
That's a common misconception... I do not have a SAT button on my '06 BOSE. I have CD, RADIO, PTY CAT, and DISP buttons.
Mine looks exactly like this:
Old Jun 28, 2006 | 12:37 PM
tkman00's Avatar
wow, i stand corrected. that's interesting. i thought anything premium equipped was SAT capable. if that's really the case, then the aux-niss might work for you. I believe the only requirement is that you have the cd changer port in the back. It would probably be a good i dea to contact soundgate.
Old Jul 1, 2006 | 01:39 AM
03NJg35's Avatar
ok, well i do have a SAT button, i guess i just never noticed it, so i order the ipod connector from mp3yourcar.com, i bring it to a local shop, they rip everything apart, doesnt work...and when it connects to my ipod, it just freezes it up....im so pissed off right now b.c they gave me the wrong info at mp3yourcar.com, they promised me that it would work and that i would not have a problem whatsoever...now i have no clue what to do...
Old Jul 13, 2006 | 10:36 AM
coffeysm's Avatar
The '06 do not have a SAT button per se. Instead it is only available when you cycle through the mode button on the steering wheel. You also need to have the Factory Satellite radio hooked up or some other device to choose it. I purchased the PAC and it works great with my IPod through a regular RCA cable.
Old Jul 13, 2006 | 10:44 AM
350Zed's Avatar
Question
Which PAC adapter did you use?
Old Jul 13, 2006 | 11:42 AM
cokecan's Avatar
Call USA SPEC and talk to them:
626-890-6410
http://akamaipix.crutchfield.com/Man...581PA11NIS.PDF
The manual for the PA11-NIS says it will work with an 03. They answered the phone right away when I called and anwered my questions about their PA11-NIS working with my 06.
At least with the 06, which none of have the SAT button, they still have a an AUX in for either the SAT module or a 6 disc CD changer (external cd changer, not the one in the dash). I suspect that the 03 has the external CD changer controls/inputs as well. When there is a source present, you get to it by pressing the CD button multiple times.
Everyone gets hung up on whether that dumb SAT button is there or not, but it isn't the only thing that tells you if you're in luck or not. You might not be able to use the factory SAT module if you don't have the button, but I believe you have a spare input laying around..
Cheers,
Brian
Old Jul 13, 2006 | 03:51 PM
coffeysm's Avatar
The AAI-NIS2 it is the same as the original NIS, but it has two aux inputs instead of one. I bought it for about $90.00 I forgot what the name of the website was though.
Old Jul 13, 2006 | 04:08 PM
350Zed's Avatar
Crutchfield confirmed the PA11-NIS will work with my '06 Bose, so I'm ordering that. I don't need iPod hook-up, but it's got a line-level AUX input too.
Old Jul 15, 2006 | 11:56 PM
  #30
coffeysm's Avatar
Yes, it is not just for IPod's anything that uses an RCA connection can utilize it. MP3, DVD, etc... I plan on using it to wire in my Sirius Sportster reciever, I just got finished adding an amp/sub and upgrading all my speakers to Infinity Kappa's. Don't feel like tearing apart my dash just yet, LOL.
Frostbite91
Aug 20, 2015 07:20 PM
Frostbite91
Aug 12, 2015 05:16 PM
Phalanx
V36 Audio, Video & Electronics
Aug 10, 2015 11:31 AM
realtalk21
Jul 20, 2015 09:07 AM
beevanhuynh
Jul 14, 2015 09:06 AM
