Trunk Rattles, Any Suggestions?
So i had my 2x JL 10" w6's + 1000/1 Amp Installed in a Z-Enclosure today. Even tho the enclosure is only .8 cu/ft, stuffing it with polyfill made it sounds very nice. Only problem is, the trunk and what sounds like either the exhaust or the liscense plate is rattling like crazy. Would you guys suggest I get the dynamat trunk kit, or has anyone had experience using Ice Guard or any other Dynamat alternatives. Also, where would be the best place to put the sound deadening, the trunk lid and sides only? Thanks for the help!
If it is the license plate, Dynamat the plate - not the trunk!
I had a funny little rattle between 3-5k RPM. I took the car to the muffler shop half a dozen times. They couldn't find it. I found it today! There was a little pebble about the size of a dime stuck (I guess not stuck enough) between the rear bumper and the frame. I found it by pounding on the bumper with my hand. Once localized, I pulled the bottom part of the bumper down enough for the little guy to jump out. All fixed.
