Bluetooth incompatible w/ Razr?
Old Jun 22, 2006 | 01:14 PM
bajaracer's Avatar
Just got the new Motorola Razr and it doesn't work with the factory bluetooth...tried my friend's older model Razr (non-mp3) and same thing. (no device found) The bluetooth worked with my previous phone, so I'm just double checking if you guys know for sure if the Motorola Razr's do not work with the factory bluetooth because if that's the case I'm going to exchange it with something that works. THANKS
Old Jun 22, 2006 | 01:42 PM
g35newbps2's Avatar
my 06 and razr works fine. make sure you are in the setup to pair phones and delte your old one maybe.
Old Jun 22, 2006 | 02:05 PM
JEVERYDAY's Avatar
My non-Mp3 Razor works fine with my bluetooth... Is it even seeing the device?
I hope you have the correct access code for the device. I had that problem with my old bluetooth headset.
Old Jun 22, 2006 | 02:07 PM
Houston G's Avatar
My razr is compatible with the G's bluetooth.
Old Jun 22, 2006 | 05:07 PM
sliderg35's Avatar
"BlueTooth" is a standard. If it is "BlueTooth" it will work with any other "BlueTooth". You have to set the car to pairing mode and then set the phone to broacast its ID. Make sure that you are NOT in "Airplane Mode" on the phone.
Old Jun 22, 2006 | 06:25 PM
GeeMan's Avatar
Buried in the Bluetooth menu on the Razr is an option called "Find Me" or something like that. At least that was how it was on my Wife's Razr when I paired it with my Bluetooth setup. Don't know what you have to do on the Infiniti side as mine is aftermarket.
Thrillryder23
V36 Audio, Video & Electronics
Dec 28, 2008 12:43 PM
ShayanZ
Not G35 Related
May 9, 2006 11:55 PM
