amp/woofer stock HU
Old Jun 25, 2006 | 09:37 PM
06BLACKMT's Avatar
amp/woofer stock HU
hey guys. I'm looking for everyone's help who has the time. I am a complete n00b with electronics.
***disclaimer: I tried reading the sticky on install but def confused myself, as it seems to speak mostly about the premium HU. Please don't tell me to do a search. Either please stay to help, or move on to the next thread. Thanks in advance!
Heres what I'm looking for help with. I'm looking to use one 12inch kenwood sub with this http://www.cardomain.com/item/KENKAC7201 kenwood amp. The specs on the amp are:
* MOSFET Power Supply
* Torroidal Noise Suppression Filter
* Copper EE Core Power Transformer
* Dual Secondary Capacitors
* Ground Isolation Input Circuit
* Cast Aluminum Sandblast Finish Heatsink
* Variable (50-200 Hz) 18 dB / Octave Low-Pass Crossover
* Switchable (150 Hz) 12 dB / Octave High-Pass Crossover
* Switchable 12 dB Bass Boost at 90 Hz
* Gold-Plated Preamp Inputs & Outputs
* High and Low Level Inputs
* 2 Ohms Stereo / 4 Ohms Mono Stable
* Blue Triangle Power Indicator
* Gold-Plated Screw-Type Power and Speaker Terminals
2-Channel Amp Specifications
* Amplifier Type: 2-channel
* RMS Power @ 4 Ohms: 150W x 2 @ 14.4V
* THD at 4-Ohm RMS Power: 0.08 %
* Bridged RMS Power @ 4 Ohms: 460W x 1 @ 14.4V
* Speaker Level Inputs: yes
* Preamp Outputs: yes
* Built-In Crossovers: HP/LP
* Bass Boost: 0 or 12 dB
* Frequency Response: 10-45,000 Hz
* Signal to Noise Ratio: 100 dB
* Fuse Rating: 2 x 30 amps
and the specs on the sub are this:
Maximum Power Handling 700 Watt
Nominal Power input 175 Watt
Sensitivity 93 dB
Impedance 4 Ohm
Response Bandwidth 25 - 800 Hz
How would I go about putting these into the G? Will i need a LOC? Please help if you have the time to tell me everything i need. It will be greatly appreciated!
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
AesonVirus
Engine - Exhaust
Sep 20, 2015 01:54 PM
Tonka211
Sep 18, 2015 09:46 AM
