V1 Remote Stealth Install
Old Jul 11, 2006 | 11:16 AM
phishloco's Avatar
Just bought my 06 MT Coupe last Thursday and realize I need a V1 bad. I have been meaning to get one for a while but just haven't done it. I had an Audi A4 before and from the forums there there are a couple stealthy installs for the V1's remote display.
Check this out
I would love to have something like that for the remote display. I plan on putting the V1 up on a visor mount and hardwiring it.
Sorry for the n00bish question but I haven't found anything with the search tool.
Thanks!
Old Jul 11, 2006 | 11:51 AM
Infiniti_Mike's Avatar
Wow that is a nice install. The only problem is that mounting the V1 (or any RD) by the sun visor is that the tint band blocks it, which effects LASER sensitivity. You might want to go to www.radardetector.net to see some installs there.
Old Jul 11, 2006 | 12:02 PM
phishloco's Avatar
Thanks, I've been there but I was hoping someone on these forums had found a G35 specific solution. I'll keep looking and post my results.
I've also seen the remote display in the mirror but that's 200+ bucks which in my opinion is not worth it. I just want a discrete place to put it that will look nice.
Thanks!
Old Jul 11, 2006 | 01:43 PM
giddyup69's Avatar
you can install it in the ashtray.
pm espresso for more info... as i believe he is the one who did the above install.
Old Jul 11, 2006 | 03:15 PM
Espresso's Avatar
The remote display unit in the ashtray is pretty simple. Just tap into the cig lighter for power and add the kill switch. The V1 itself is on the tint band on the passenger side corner. I placed it there cause from the outside of the car, you can't see it.
Old Jul 11, 2006 | 08:25 PM
n1cK's Avatar
G35 6MT
you may get interference or reduced signal strength because of that tint band.....
Old Jul 11, 2006 | 08:27 PM
n1cK's Avatar
G35 6MT
oh by the way, here's my V-1 install!
Old Jul 14, 2006 | 01:36 AM
n1cK's Avatar
G35 6MT
Originally Posted by InFaMOuS_G
damn that install is nice!!!
my fav. is still the one in the ash tray. that fact that it hides away makes it cool
thanks!
Old Jul 14, 2006 | 01:28 PM
sliderg35's Avatar
As far as placement of the unit goes, this works well for me. The sensor falls just below the tint band but you have lots of room to adjust as required. You can't see it from inside the car because it is hidden by the mirror.
Attached Thumbnails V1 Remote Stealth Install-passport1.jpg   V1 Remote Stealth Install-passport2.jpg
Old Jul 14, 2006 | 02:04 PM
n1cK's Avatar
G35 6MT
is there no rear facing sensor? and how could you see the display?
Old Jan 20, 2007 | 08:52 PM
n1cK's Avatar
G35 6MT
what kind of switch did you get for the kill switch? how did you wire it to the concealed display? which wires are used? all i know is that green is ground, and red is +12VDC. what are yellow and black?
Old Jan 20, 2007 | 09:07 PM
filanj's Avatar
ashtray installs are laaaame
https://g35driver.com/forums/showthr...=122220&page=3
filanj's Avatar
mute
https://g35driver.com/forums/attachm...8&d=1167338313
Old Jan 20, 2007 | 10:33 PM
Meatshackle's Avatar
Deep Sea Moderator
Here's one inside the gauge cluster.
Old Jan 21, 2007 | 01:26 AM
n1cK's Avatar
G35 6MT
well, havin' the thing stick out in the steering column is pretty lame, too. someone should do something like this!
