PAC SWI-ALP help
Old Jul 11, 2006 | 11:53 PM
twlightG35's Avatar
PAC SWI-ALP help
I was wondering if anyone out there has gotten this Steering wheel control box to work. The instructions for PAC stink to put it politely. If any of you have I could sure use some help. Thank
Old Jul 12, 2006 | 12:19 AM
conq's Avatar
Are you having a problem with wiring or programming?
Old Jul 12, 2006 | 07:45 AM
twlightG35's Avatar
Not sure. I'm having problems when trying to program but it could be because of the wiring. I have the mode set to 3 but when I try to program the volume up the led stays on then flashes 3 time which I think means that the programming is done.
As far as the wiring goes I have the 150 ohm resistor to pin 23 (Green wire) and the 47 ohm resistor to pin 22 (Red). Then the two resistors connected to the white wire of the PAC harness. I have attached the pin 25 (Yellow) to chassis ground.
Old Jul 12, 2006 | 11:25 AM
conq's Avatar
You did wire it correctly. You might need to check your connections, the light should definately go off when you press vol up. Make sure that ground wire is ok.
Old Jul 12, 2006 | 11:59 AM
twlightG35's Avatar
Thanks I'll have to take another look at it tonight.
willdogs
Dec 8, 2015 11:32 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
AuAltima3.5
Sep 13, 2015 11:48 AM
coasterlvr
Apr 8, 2004 11:13 AM
