Help: Bose Amp and Subs Install?
I was wondering if I need a special rca convertor in order to install a 2 channel amp and 2 10'in subs to my Bose system in my 06g35 coupe? A shop told me I could not use a regular rca convertor, because the Bose system will blow? Is this true?
Bose
The installer correct in stating a regular speaker level converter will not work...it wont explode or anything though. Regular speakers run @ 4ohms while the Bose output is not. If you change your Bose speakers to aftermarket it will lose half the volume of the stock Bose. Don't worry coz JL Audio makes a product called Clean Sweep that converts your Bose signal so you can install Amps. It also has a built in eq and an input for an IPod or any other external source. This is the exact set up I will be using for the moment until I can save up some $ to get a Pioneer Z1.
I am working on my system right now and I will have a run-through with pics on it since it will be a d-i-y project. To give you a preview. The set up will consist of a 1 4-channel JL Audio amp, 1 2-channel JL Audio amp, Boston Acoustics Pro Series seperates for the fronts, the oem rears will stay for now. Either 2 JL Audio 8' or 10' subs fiberglassed into the trunk--it will be housed where the jack is and the opposing side as well. The sub size will depend on space constraints and weight.... I really dont want to upset handling dynamics of the G as much as possible. The 2 amps will go on the left and right wheel arches towards the back of the car-pedestal mounted so it looks like its floating in the air. I figured it will take me a month to finish doing it on the weekends.
Check the linhttp://mobile.jlaudio.com/products_cleansweep_pages.php?page_id=94k out.
Originally Posted by Gxtreme
The installer correct in stating a regular speaker level converter will not work...it wont explode or anything though. Regular speakers run @ 4ohms while the Bose output is not. If you change your Bose speakers to aftermarket it will lose half the volume of the stock Bose. .
The best mod any us did on our Bose equipped Acuras, was to swap out the speakers. The drop in volume is not even noticeable. Why? Because the new speaekers (Infinity, Polk, Alpine, etc.) or much more efficient than the Blose.
Of course, you spend gobs more money and upgrade to whatever you want. But if you want to save some money and still make a difference, just swapping the drivers helps a lot. Granted, I have not tried it on the G car, but would not expect it to be any different.
Ok, just to let you guys know, I am not swapping out any speakers. I am just trying to add an amp and subs to my existing system thats it? Thats why I ask if I needed a special convertor or can I use just any rca convertor? thanks
Originally Posted by fortified
Simply not true!
No end to what is possible for an improvement. The potential is there.
I agree, there may be a small drop on volume, but I think I cranked it up because it just sounded better than the Bose! I would never have bothered listening to the Bose at that level. But that was a test. There is certainly more to good audio than volume. I find the clarity of the Bose in the G35 superior to the MDX.
I am sure I will be making some changes in the future, regardless.
Tyler's03G
Aug 13, 2015 10:04 AM
Thunderaan
Jul 22, 2015 07:40 PM
