Pioneer Avic Z-1 06 install
Hey guys, I'm planning on buying a pioneer avic z-1. I have 06 g35 AT coupe, all standard.
Im going to have someone else isntall it and wanted to make sure I have everything I need in regards to dash kit / mods. So far I've found this...
http://www.grubbsperformance.com/Mer...e=G35CoupeDash
Do I need anything else to make this fit? I heard that because it is an 06 I DONT need the DD bracket...
...is that true?
I'm also planning on installing the IPOD adapter and the unit which allows me to keep my steering wheel controls (forgot what that's called). If someone could confirm that all I need is the DD finisher that would be great. Also if anyone knows a trustworthy place to do the install around Culver City CA that would be helpful. If not Circuit City will have to do. Thanks guys...
...is that true?
i've heard you DONT need the bracket, but if u wanna keep the dual climate u gotta fork over the 200+ thingy for the AC controller. Oh the ipod thing is the USA-spec NA11-PIS. Just got mine couple days ago, good luck!
Originally Posted by emtguy05
yup
Climate control is built into the head unit, regardless of dual zone or not.
You MUST buy the replacement
IF you have dual zone, you will need to modify the new controler by taking the dual button off the origional and soldering it in place.
G35Mass is correct... behind the stock dash cover, the stock radio and A/C controller are all on the same circuit board.... you WILL need the new A/C controller either way.
Originally Posted by G35 Mass
Uh, No.
Ok, So I just need the DD finisher, and the ac controller....
Plus of course the Z-1 correct? Thanks so much, you guys have been really helpful.
only one question i can't find an answer to
i have the 06 with premium so i already have bluetooth. am i still going to be able to use that and do i still need to get that accessory for the bluetooth for the z1?
I figured i wouldn't make a new thread for this question. But clarification on the issue would be great. For an 06 G35....do you or do you not need the DD bracket. I understand the need for the A/C controlller, and DD finisher, but is the bracket necessary? Also, I live in Houston and was wondering if anyone had any insight on a good place to go for the install. I'm going to order all the parts....just need the installation.
...if you arent sure? just get them all
