Installing BT Car Kit - HELP ASAP!
Old Aug 3, 2006 | 04:57 PM
UFGatorG35's Avatar
I have not personally used or installed a bluetooth car kit, but a customer needs to know if anyone has any idea about installation time. They should be fairly similar in times, but just in case the unit in question is the Motorola HF850. Any help is appreciated!
Old Aug 4, 2006 | 02:35 AM
bconrey's Avatar
Depends on how integrated you want. I think the 850 comes with its own speaker, so the only thing you're tapping into is power and ground. Add connections for the control unit, one for the mic, one for the brain, and you're done. I'd really put the amount of time against your intended source for power - if you're ok with the cig lighter circuit, you're taking off two panels and the console trim piece, shouldn't be more than a couple hours.
If you want to pursue the stereo-mute or integrate with the car's sound system, add plenty of time for additional wiring and trouble-shooting.
Old Aug 4, 2006 | 09:44 AM
UFGatorG35's Avatar
Thanks!
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
beevanhuynh
Jul 14, 2015 09:06 AM
