Differential LOC needed?
Old Aug 1, 2006 | 03:49 PM
blacksheep1998's Avatar
I have 2 problems with my aftermarket amp I have added.
1. Sometimes when i turn on the car it sounds like the speakers are only getting a few volts of power to them. I have checked the connections and they are good. It sounds muffled and very low volume, turn the volume way up, and something happens and the speakers sound normal, or if you cycle the ignition it will work fine. Is this caused because my Alpine amp does not support Differential speaker inports, so it is getting confused as to the actual sound level requested from the HU? Would a Differential LOC help?
2. After running my amp wire down the passenger side, it seems the car is low on power, or wants to delay shifts sometimes. I tried searching but the search function does not work very well. IIRC someone else has this problem and the routed the power cable to the amp away from the ECM loom? My cable is running through the same grommet, and right beside this loom.
Thanks,
Pete
Old Aug 3, 2006 | 11:09 PM
bump.... Doesn't anyone run somthing other than JL amps? Someone has to have an alpine out there...
Old Aug 4, 2006 | 11:39 AM
figured it out. One of the connections going to the speakers was touching the case for the amp chassis grounding that connection and causing the amp to power down. As for th ECU I think that was because the battery had been disconnected.
Pete
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
Blakearold
Aug 19, 2015 10:20 AM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
Thunderaan
Jul 22, 2015 07:40 PM
gabe3d
Drivetrain
Jul 22, 2015 11:49 AM
