Rear Differential help needed
Old Aug 10, 2015 | 07:16 PM
myGspot's Avatar
Hey guys,
Wanted to find out if anyone on here knows if the base 350z 6MTrear differential is the same as 2005 5AT diff?
Reason why i am asking is i have a 5AT vlsd dif and i am going to do a 3.9FD change and putting in a quaife lsd as well. I have a spare 6MT diff from a g35 but i think the quife lsd will not fit into it properly since it requires base model diff. Does anyone know if they are same size ?
Also will the VDC still work with a base 350z diff?
please help thanks
Old Aug 11, 2015 | 01:46 AM
Mr. Brooks's Avatar
Thumbs up
If the Quaife differential you have is for a 5 speed automatic. Why not put it in a 5 speed automatic. You'll still get better performance.
Old Aug 11, 2015 | 11:58 AM
myGspot's Avatar
the diff i have is the QDF11L which is for the base model Z open dif.
I have a dif from a manual 6MT VLSD that it needs to go into. I can not upgrade automatic dif to a 3.9 gear since they do not make ring gear for that dif.
Therefor i have no choice but to mod a 6MT vlsd dif.
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
gabe3d
Drivetrain
Jul 22, 2015 11:49 AM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
