help with bluetooth install
Old Aug 7, 2006 | 10:09 AM
Texasscout's Avatar
I just bought one of the Motorola bluetooth hands free kits. The 850 model. What wire do I connect the mute to on the Blose HU to get it to mute when a call comes in?
Old Aug 7, 2006 | 10:29 AM
amthar's Avatar
The Bose doesn't have a mute wire. I'm sure there is a way of making a mute, but I'm not sure what it is
Old Aug 7, 2006 | 10:47 AM
Justification's Avatar
I installed the bluetooth on my friends 03 passat w8 and we ran into the same problem. However, his head unit had a place for the mute wire to go, just no wire to splice into. We had to take a wire and a metal connection bought at Radio Shack to connect it to the HU.
However, for the G, you are going to have a little bit of a harder time. I don't remember how to do it, but when I was going to install it on my 05 G35 coupe, I did some research on this forum. I don't remember exactly what to do, but there as a thread which talked about needing to make a bypass wire of some sort to work for out HU. Also, it talked about needing to convert the amount of power going to the bluetooth.
My suggestions, have a professional install it. It is not as easy to install on the G as it is on other cars. OR.... check the forum, there is a thread somewhere on it.
Old Aug 7, 2006 | 05:16 PM
bconrey's Avatar
Alternatively, you can build a relay setup to shut off power for the Bose amp. I think the handsfree kit grounds the mute wire when enabled, so you'd need to stick a relay on that, then another relay (normally closed) on the power for the Bose amp.
Use at your own risk and all that, but it can be done.
R350k5
Oct 1, 2015 08:41 PM
gatorglaze
Sep 10, 2015 12:03 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
