nav/tv tuner G35 Coupe
Old Oct 14, 2003 | 12:11 PM
testerg35's Avatar
To all who have already installed the AV Electronic Nav/TV tuner... where did you put it and what dvd player did you use? I would like a dvd player that plays DVD-R, SVCD...
Thanks,
testerg35
Old Oct 14, 2003 | 02:41 PM
MyGUnit's Avatar
Re: nav/tv tuner G35 Coupe
i put the actual unit below the feet of the passenger side..and i put my ps2 in the trunk, running extension cords for the controllers to the front
Old Oct 15, 2003 | 12:36 PM
super_g's Avatar
I'm using this one ...
http://www.mp3playerstore.com/stuff_...d/dvd/FD-5.htm
it plays all my dvd -r's and svcd's just fine... don't know about the dvd +r's though...
Old Oct 15, 2003 | 02:32 PM
testerg35's Avatar
super_g, where did you put the nav/tv tuner and the dvd player?
thanks....
Old Oct 15, 2003 | 06:22 PM
super_g's Avatar
haven't put them in yet.. hopefully next weekend... but it seems the passenger side kick panel can hold the nav/tuner.. the dvd player is another problem... i'd like to have access to it from the cockpit some i'm thinking custom mount in the center console/armrest..... i've seen others do that... but ideally i'd like to move the nav dvd player to the trunk and put this player in that spot... not sure yet... i'm hoping someone with more nav/wiring experience can shed light on that....
Old Oct 15, 2003 | 07:19 PM
Meatshackle's Avatar
Deep Sea Moderator
I should have pics of my install by the weekend.
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, & TVs all up in the headrests.
Jax, FL
Old Oct 15, 2003 | 08:32 PM
LakersCentral's Avatar
holy crap TrentaCinque, that is hot. how much did that run u? u able to play the same dvd & have it appear it all the monitors? i'd like to know where you got that done & what ur runnin. thx, B.
<font color=yellow> &lt;&gt;&lt; </font color=yellow>
<font color=purple> G-UNIT </font color=purple>
Old Oct 15, 2003 | 08:36 PM
i was just about to buy the fd5-tv model from that site when i saw this post. so does the fd5 run well? have you tried dvd discs in it yet? is it true that you can do anything without it skipping? how did you hook that into the nav? thanks for any & all info. B.
Old Oct 15, 2003 | 09:32 PM
super_g's Avatar
haven't hooked it up yet... but i did test the fd-5 and it runs pretty good.. i tested dvd's, dvd-r's, svcd's, mp3's.... all run just fine... i like the A/V inputs in the front in case i do want to play ps2 or something i can easily hook into it... dunno about the anti-skipping... i suppose i could try running around the room with it pretending i'm a g...
i also just talked to guys over at PAC and they're pretty close to releasing the adapter for our Bose system.... that way we can feed audio directly into the Bose and not have to use the FM modulator or the cassette method... i might just wait for them and do that all at once...
Old Oct 16, 2003 | 01:22 PM
PAC? how will the adapter work? direct stereo cd sound?
yea, the front AV inputs is def a plus, plus the fd5-tv has a tv tuner. i wonder if anyone has tested that one out yet. where are you gonna put it in the car? i was thinkin maybe under the passenger seat? or in the glove? did you by any chance test out mp3's on a dvdr? they claim that you can hold it upside down and shake it, and it still wont skip. It might be hard to simulate a G, but if you try, take some video ;.p
Old Oct 16, 2003 | 07:24 PM
Deep Sea Moderator
There's a post on this forum with the details of the install. It's still on the first page. I'm running a ps2 and it can go to all 3 or just the back 2. Thanks.
Russ
Jax, FL
Old Oct 17, 2003 | 02:47 PM
can you send a link to the post that contains the install...i couldnt seem to find it...or at least the title of the link so I can search for it. thx
Old Oct 17, 2003 | 11:41 PM
Deep Sea Moderator
The title was "headrest monitors installed". I didn't do a step by step yet. I'm waiting to finish it up. My car is stripped down completely right now. That thread will give some info on the monitors themselves.
Russ
Jax, FL
Old Oct 18, 2003 | 08:13 AM
Greg40MD's Avatar
I have installed the AV Electronic unit in my coupe. I put the tuner under the passenger seat and the DVD player hanging in my trunk. I have the Playstation sitting on my rear seat so I can remove or hide it when needed. The TV does not work well because I have tinted windows. I need to get a booster antenna. The sound is not terrific because it is not directly connected to the Bose. It is via FM modulation at 89.1 on your radio. Its not a clean sound. The remote head phones work well. I had to put the rear camera inside my rear window for the reverse. You can disconnect the brake wire to use it while you are driving if you want to risk it. Otherwise your passenger would enjoy it.
Old Oct 28, 2003 | 08:17 PM
Deep Sea Moderator
Why did you have to put your camera inside? It won't go above the license plate? I'm thinking of getting it.
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, PS2, & TVs all up in the headrests.
Jax, FL
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Aug 3, 2015 02:44 PM
laksjd84
Jul 24, 2015 05:12 PM
