SEDAN Bose Amp Wire Colors - Please Help!
Old Aug 26, 2006 | 09:21 AM
jeremyf0923's Avatar
Getting desparate - posted something in the G35 Sedan section and have gotten very little response - hopefully someone can help me out today because I wanted to do my install this weekend. I did a full install in my previously owned Coupe and I did the following:
I tapped into the head unit output rear right and left coming from the Bose amp and ran it to the LOC. In the Coupe's Bose amp the wire colors were as follows: head unit output rear right + = BLUE, head unit output rear right - = PINK, head output rear left + = TEAL, and head unit output rear right + = PURPLE.
With that said, I have searched and searched and CANNOT get confirmation that the wire colors coming from the Bose amp in the Sedan are the same. My question is what are the correct colors for the wires to tap the LOC into to ultimately send a signal to my amp?
Please help!
Thanks!
Old Aug 26, 2006 | 01:36 PM
footmasta's Avatar
in my last post they gave me this link, see if it helps you out.
http://digitalwheelz.com/diy/
Old Aug 26, 2006 | 10:48 PM
blacksheep1998's Avatar
posted to your other thread, but here you go:
Here is what you need:
The box to the right of the factory sub is for the Bluetooth, if you have sat there will be another box on top of that one.
For the LOC the rear channel from the wiring diagram is
LR+ BR (pin 26), LR- Y (pin 25), RR+ L?(pin 24) RR- P (pin 23)
To tell which pins are 23-26 pull the big black connector from the bose amp, there will be 4 empty spaces at the start of one row, and 2 on the other. The row with 2 empty spaces is pin 21 (empty) pin 22 (empty) then pins 23-26 are the rear channels.
Pete
EnCr1pt3d
Jul 8, 2019 02:48 PM
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
Frostbite91
Aug 2, 2015 04:59 PM
kd03g99
Jul 30, 2015 11:24 AM
Thunderaan
Jul 22, 2015 07:40 PM
