Seat out = Flashing Airbag Light
Installed an amp under the F/R seat. Installer took the seat out and started the
car. $99 bucks at the dealership to reset the airbag controller (installer will cover).
Dealership said that the key in ACC position will not cause a trouble code to
be stored. On or Run will.
Re: Seat out = Flashing Airbag Light
Yep this happen to me on my BMW. I was installing an amp and had rear seat out. I turned the ignition to ACC and the SRS light went on. Later I found out, this is due to the SRS sensor was located under the rear seat.
G35C 6MT / AMG E55
G35C 6MT / AMG E55
Wow. Didn't know that. I had both of my seats out last week but luckily didn't start the car. Thanks.
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, & TVs all up in the headrests.
Jax, FL
Russ
Jax, FL
no, that was while installing a new shift ****. I think it was determined that an airbag sensor/wiring is in the area of the shift **** or something.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
I'm the one with the airbag issue. Don't pay the dealer to reset you car, it is described somewhere on this forum or freshalloy how to do it with just turning the key on and off in a certain sequence. I did it after the airbag was replaced and it worked like a charm. Just do a search, because I don't remember what it was now.
Silverstone 6MT Maya DTM 20's
Micale757
Lighting
Apr 8, 2020 10:46 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
