what size headreast fit in the G..?
Old Oct 16, 2003 | 04:28 PM
DizG_OwnesU's Avatar
wat^ everyone, This is my first post so bare with me now... Does anyone know what is the biggest size headreast Tv's that i can fit in the G35 sedan..? Any info and pics would be great.. Thanks.
Old Oct 16, 2003 | 07:26 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: what size headreast fit in the G..?
You could probably squeeze a 6.5" in there.
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, & TVs all up in the headrests.
Jax, FL
Old Oct 16, 2003 | 08:31 PM
haYanNoize's Avatar
I do believe Savv makes a 7"+ drop-in headrest. (Drop-in means it replaces your factory head rest so you don't have to do any cutting to the original leather).
P.S.
For those who care. I drive a Silver Sedan 6MT CA license plate "KRZ HAYN" = "Krazy Hawaiian". A "Shaka" is always welcome.
Old Oct 16, 2003 | 10:23 PM
Well I'd rather keep the factory headreast... I know the sedan's headreast are a little smaller that the coupes.. does anyone know what would fit the sedans head reast..?
Old Oct 17, 2003 | 10:47 AM
RacerX's Avatar
I'm putting 5" Accelevision monitors in my sedan. Just about done with the first, so I'm not quite ready to post pictures. But I can point out a few things.
-These headrest SU** for mounting monitors. That did not stop me though.
-I doubt you can use much bigger than a 5" monitor. Maybe 6" if it's really shallow.
-The headrests slope forward sharply. Terrible viewing angle, especially for children. The Accelevision monitors tilt down 15 degrees, which helps this considerably.
-The headrest struts are pretty close together, even a 5" won't fit between them. Because of the tilt feature, the Accelevision moniotors need a full 1" below the surface. These headrests will not give you quite that. When I mounted them, the shroud wasn't quite extending down to the finished back surface. Two choices I saw: A] Make a custom fiberglass shroud a little deeper than the one that came with the monitors. B] Add upholstry stuffing under the vinyl around the edge of the shroud to bring the surface up to the monitor. I chose option B, but it's definately not a perfect solution, the back of the headrest around the monitor looks a bit puffy. But it works.
04 G35s 6MT BS Aero Kit/Nav/Prem
Warning: Objects in Mirror Are Losing!
Old Oct 17, 2003 | 02:53 PM
Thanks alot for the ideas... Not to sure what i will do yet, But i will post when i finish.
Old Oct 17, 2003 | 11:43 PM
Deep Sea Moderator
Instead of trying to fit the housing between the posts why not trim the housing to go over the posts? I guess with the swivel types that might be a prob.
Russ
Jax, FL
Old Oct 20, 2003 | 12:28 PM
RacerX's Avatar
<hr></blockquote>
When I did my install I did go over the posts. But the Sedan headrests are VERY different than your coupe's. The limiting factor is not really the posts as it is the curved edges of the headrests.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
