Amp help
Old Sep 7, 2006 | 06:16 PM
Obsidian G35's Avatar
Amp help
What size amp would you use to push 2 JL 10W6V2's? I'm currently running a single 10W6V2 with a JL 500/1 amp, but want to add a 2nd sub..
Thanks
Old Sep 8, 2006 | 12:41 AM
Igor911's Avatar
just get a 2nd 500/1....
Old Sep 8, 2006 | 06:16 AM
imalazeeass's Avatar
or a 1000/1..
Old Sep 8, 2006 | 12:34 PM
redlude97's Avatar
I would try it with just the 500/1 first. If you double your cone area with the same amount of power, you should see some gain in dB, so it may be enough for you. I would try this first and then decide if you need to upgrade
Old Sep 8, 2006 | 02:54 PM
machavez702's Avatar
The 500/1 will run it.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
JustinMKN1
Sep 18, 2015 03:40 PM
