Battery Terminal Fitment
Old Sep 18, 2006 | 05:56 PM
G-ThreeFizzle's Avatar
I currently have a Duralast Gold battery I'm using on my coupe, but the terminal isn't as "secure" as I'd like it to be (the Duralast terminal is a little skinnier than the OEM terminal). So, I basically just wrapped some aluminum foil around the terminal to make it somewhat thicker. Is this a good way of going about this? Or, is there something a little more "professional?" Thanks!
Old Sep 18, 2006 | 09:46 PM
fortified's Avatar
Change the end of the cable, the terminal, or just get a new cable. Get a good copper or plated one. Do not use aluminum foil as a filler, it will compress and loosen over time and cause you more grief.
http://www.jcwhitney.com/autoparts/B...000921/c-10101
Old Sep 18, 2006 | 10:01 PM
khsonic03's Avatar
Aluminum is no good. It is not a good conductor of electricity. Def get a better terminal clamp.
Old Sep 19, 2006 | 01:03 AM
Triji's Avatar
Take a pair of pliers and squeeze the SOB a bit to make it oblong... It worked for me
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
the93owner
Oct 4, 2015 09:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
