Space in Sail Panel
Old Sep 27, 2006 | 12:04 PM
nnewton123's Avatar
Space in Sail Panel
Did a search, didn't find what I want to know...
How much room is there in the sail panel?
I've got a set of focal utopia components which have fairly large tweeters and just wondering if they will fit behind the sail panel. I'd like to keep the inside looking stock (minus the avic-z1 I will put it). Anyone have experience with these? I believe the tweeter model is TN-51. Set is 165w.
Old Sep 27, 2006 | 02:40 PM
gramdacious's Avatar
I fit some 1+" diamond audio tweets in the stock sail panel with a few modifications. If you have a dremel or something like that you can remove some of the inner plastic material to make them fit without affecting the viewable outside. The diamond tweets have a large diameter (with the trim ring) and are thick as well but I got them to fit and it looks stock. Just becareful not to remove too much plastic on the other side of the sail panel and you should be fine.
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
6spdGspot
Oct 5, 2015 01:55 PM
leo38cheng
Sep 29, 2015 05:43 PM
