Help - Need Specific Ground/Hot Under the hood.
Old Oct 23, 2003 | 07:58 PM
redwillow's Avatar
20 Year Member
Anyone know where i can tap into a wire (somewhere under the hood) that goes to Ground ONLY when the ignition is OFF??
....OR goes to 12v (from gound) ONLY when the ignition is OFF?
thanks.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Oct 29, 2003 | 11:13 PM
GORILLAG35's Avatar
Re: Help - Need Specific Ground/Hot Under the hood.
what are you looking to do ? cuz if you only want a ground source at ign. off all you have to do is rig a relay using an ign. (key on) power source as the energizer lead of the relay
Old Oct 30, 2003 | 08:51 AM
redwillow's Avatar
20 Year Member
i was asking for <a href="https://g35driver.com/forums/showflat.php?Cat=&Board=FAQ&Number=128616&page=0&v iew=collapsed&sb=5&part=&vc=1">this</a>
... but i've just hooked it up hot all the time and it functions just fine.
Thats a good suggestion though. Your saying use a relay to take an input signal from the ignition to trigger a constant ground.
magnetism80
Feb 1, 2019 10:00 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
