Replacing Door Speakers
Old Oct 13, 2006 | 01:47 PM
jcv423's Avatar
I need to replace the front door speakers in my 06 non-Bose 6mt coupe. Can anyone provide me with a quick walkthrough of replacing the speakers. I really just need to know how to access the speaker, take the whole door panel off? pry off the grill? etc. THANKS!!
I apologize if this has been asked before but i did search around and didn't find this info.
Old Oct 14, 2006 | 02:17 AM
Otacon132's Avatar
gotta remove the doorpanel - its simple i did it without reading on it,t heres some clip off under the door sill, and inside the handle, you remove the little cap - just take your time to find all the screw's
Old Oct 14, 2006 | 04:44 PM
g35rcr's Avatar
on the handle of the door there is a little notch take a flat head driver and pop the latch loose there then pry back the handle cover. next in the door opener by the tweeter there is a plastic cover take a small flat head and pop that cover off. remove the screws in handle and in the door mechanism. once you do that start at the bottom of the door and work loose the plastic rivets, the door will come right off. if you want to completely remove the door cover pop up the window button cover and unplug the harness.
xluke
Jul 30, 2016 01:48 PM
JMSABO
Aug 4, 2015 11:58 AM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
