mono or stereo
Old Oct 28, 2003 | 01:09 AM
tig488's Avatar
mono or stereo
im hooking up my subs, 2 jl 10w3s, to a 500/1, what do you guys suggest i do, 2 channel stereo, or 1 channel mono. the box is sealed and i listen to all types of music.
2003 G35 Silver/Graphite 6MT Prem Cp
19" Gunmetal TE37s 275/30 Michelin Pilot Sports
kg/mm supersport springs
custom camber rods
injen CAI
Alpine/JL Audio/Stinger
double din, he-he-he
Old Oct 28, 2003 | 01:26 AM
GrandMaster's Avatar
Re: mono or stereo
Do you have a choice? if you are using a JL Audio 500/1 it has only 1(mono) output. It does have what appears to be 2 outputs, but it should say mono output only on it. Do you have 2 500/1's?
-Louis
2004 Diamond Graphite Sedan
Old Oct 28, 2003 | 04:33 AM
g35audioman's Avatar
Re: mono or stereo
even if you had a 2ch amp...you might as well run the subs as one channel since they are producing bass and do not need a stereo signal. Assuming you have dual 4 ohm coils, you should be able to get a 4ohm load when wired in series and that will work out well. In any case, wire them together and connect them to the amp..you'll be fine.
Old Oct 28, 2003 | 09:56 AM
tig488's Avatar
Re: mono or stereo
sorry guys, had a brain fart there, 500/1=mono output only.
custom camber rods
injen CAI
Old Oct 28, 2003 | 10:05 PM
g35mt's Avatar
Re: mono or stereo
tig,
are u running at 2 ohm? If you can, you should. Also the amp should be able to run at 2 ohms with no problem.
g35mt
Old Oct 28, 2003 | 10:32 PM
amg35's Avatar
Florida G35 Club
Re: mono or stereo
Not necessarily. One of the advantages of the smart power supply of the JL amps is that they produce constant ouput throughout their operating impedance. While a 2ohm load would produce slightly more power, the amp will produce substantially more heat. As with most electronics, heat is bad. The biggest factor for which impedance to present the JL Amp is the impedance of the woofers you own. The 10W3 series is offered in dual 2, dual 4, and dual 6 ohm impedances. Most of all, have fun and listen loud, G style.
Take care,
amG35
2003 Silver Sedan
seagrasser
May 3, 2022 09:43 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
NailBomb
Oct 28, 2015 07:53 AM
mattdg35
Sep 14, 2015 11:28 AM
2014g35x
Sep 11, 2015 07:53 PM
