Double Din Antenna Question
Old Oct 17, 2006 | 10:35 AM
speedgeek's Avatar
I've searched with no luck
So I’ve been running my Avic D1 for a while now and love it. But I’ve had no radio reception, the antenna is plugged into the head unit with the correct adapter, but I’ve read threads here about our antenna being powered. Since I replaced my head unit I’m thinking my antenna is not getting power. Does anyone know the wire that should be getting power for the antenna, or some way to test this? Thanks for any info you can provide.
Old Oct 17, 2006 | 10:44 AM
nyclifeg's Avatar
The antenna in the G is in glass not power. I would check all your connections and make sure you used the right plugs. I installed the same unit and it gets perfect reception.
Old Oct 17, 2006 | 12:05 PM
khsonic03's Avatar
There is a wire that is for the power antenna in the stock harness behind your HU. The new HU powers up the antenna signal booster in the rear C-pillar via this wire. You probably forgot to hook this up.
Old Oct 17, 2006 | 12:13 PM
speedgeek's Avatar
Thanks, sounds like that's what I missed. So...from my Avic D1..what wire would I connect to the stock harness? Any info would be GREAT. Thanks!!
Old Oct 17, 2006 | 01:20 PM
firefox's Avatar
So when you did the install, you should have purchased a Scosche NN03 with the following wires:
Yellow = 12 Volt Battery/Constant (12V+)
Red = 12 Volt Ignition/Switched (12V+)
Blue = Power Antenna
Blue/White = remote Turn On (12V+)
Orange = Illumination/Dimmer
Black = Chassis Ground (12V-)
White = Left Front Positive (LF+)
White/Black = Left Front Negative (LF-)
Gray = Right Front Positive (RF+)
Gray/Black = Right Front Negative (RF-)
Green =Left Rear Positive (LR+)
Green/Black = Left Rear Negative (LR-)
Violet = Right Rear Positive (RR+)
Violet/Black = Right Rear Negative (RR-)
The "Blue = Power Antenna" is the one you are looking for. This should be connected to the blue wire from the AVIC-D1 harness as illustrated in the attached.
File Type: pdf
Old Oct 17, 2006 | 03:24 PM
speedgeek's Avatar
Thank You, Thank You! Awesome info, I greatly appreciate it.
Crappyday
Aug 27, 2015 10:26 PM
Frankieg35
Aug 15, 2015 10:49 PM
itztwinki3
Audio/Video/Electronics
Aug 1, 2015 12:58 AM
kd03g99
Jul 30, 2015 11:24 AM
