Amp Location??
Old Oct 28, 2003 | 07:35 PM
gumpdriver's Avatar
Montgomery's Finest
Amp Location??
I know it has already been asked but i can not find it....
But where is the amp.. located?? and one more how is everyone replacing the factory head unit.??How are you doing the molding or cutting plase advise me on it??
The sky is the limit
350gt Ride on [img]/w3timages/icons/laugh.gif[/img]
Old Oct 29, 2003 | 12:08 PM
davey2003's Avatar
Re: Amp Location??
IN the coupe the amp is left of the spare tire. Just remove the spare tire and there are 2 screws that hold the left plastic cover down. Then just slide it out and there you will see the amp. There are an additional 2 screws holding it down. Watch out cause it does get hot.
Everyone is replacing the HU with the double din and getting the A/C controller because the HU is attached to the A/C controller.
Old Nov 1, 2003 | 05:59 PM
gumpdriver's Avatar
Montgomery's Finest
Re: Amp Location??
ok know i am kinda new tothe double din?? Please explain..
Old Nov 1, 2003 | 09:58 PM
davey2003's Avatar
Re: Amp Location??
the double din replacement is where you change your stock center console with the a double din unit meaning 2 aftermarket stereos can fit. You can put in a stereo and then add a dvd in there if you'd like. The possiblities are endless. Just do a search for it in this forum and you should find more than enough info on it. search for "double din"
Old Nov 2, 2003 | 06:25 PM
G35_PR's Avatar
Re: Amp Location??
Where is the AMP in the sedan?
Old Nov 2, 2003 | 06:27 PM
amg35's Avatar
Florida G35 Club
Re: Amp Location??
Underneath rear deck in trunk. Amp is on the driver's side.
amG35
2003 Silver Sedan
Old Nov 2, 2003 | 06:45 PM
gumpdriver's Avatar
Montgomery's Finest
Re: Amp Location??
even with the 160 watt stero system??
Old Nov 4, 2003 | 07:37 PM
gumpdriver's Avatar
Montgomery's Finest
Re: Amp Location??
Help PLEASE?????
Old Nov 4, 2003 | 11:04 PM
amg35's Avatar
Florida G35 Club
Re: Amp Location??
I would assume the amp is located in the same place with both stereo options. Take a look under the rear deck and see if you see a 'black box' with a molex plug coming out.
Good luck,
amG35
2003 Silver Sedan
Old Nov 4, 2003 | 11:12 PM
gumpdriver's Avatar
Montgomery's Finest
Re: Amp Location??
Found out i do not have one.... Called the dealer today..That leaves a world of options now with the stock HU.Learned if it does not say BOSE on the HU no system.
BfloG35
18 Inch
Apr 27, 2017 01:13 PM
ZoominG35
19 Inch
16
Oct 30, 2015 05:44 PM
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
JustinMKN1
Sep 18, 2015 03:40 PM
pasjr1972
Sep 1, 2015 10:17 PM
