View Poll Results: What color should i paint the box??
Red
2.70%
Neon Blue
13.51%
Yellow
0%
Orange
2.70%
White
2.70%
Silver
29
78.38%
Voters: 37. You may not vote on this poll
My Custom System --Fiberglass--
Old Oct 21, 2006 | 01:45 PM
Pauliejr's Avatar
Hey i should be completing this whole system in about a week.
I have A OB G35 (Obsidian Black) Vote for color of box
I am using Two GroundPounder Amps and 2 Ground Pounder Amps. I Upraded all of my interiors with Atlas speakers i will post pictures of the subs and the interior as well as the specs if N e one requests it.
Below i have Pictures of my box so far it is going to be finished up within the next few days. the two amps are goin in the boxes and the subs in the circles. this thing fits the entire trunk, and takes up the whole floor pretty much....enjoy
Attached Thumbnails My Custom System    --Fiberglass---g35_box_002.jpg   My Custom System    --Fiberglass---g35_box_001.jpg   My Custom System    --Fiberglass---g35_box_003.jpg
Old Oct 21, 2006 | 01:50 PM
Calvin's Avatar
Overglorified Altima
what color is your g?
Old Oct 21, 2006 | 01:51 PM
Pauliejr's Avatar
Obsidian Black and trunk is all black
Comments??
Please vote on Color!!!
Old Oct 21, 2006 | 02:20 PM
ttrank's Avatar
Grocery getter
Silver or black.
Old Oct 21, 2006 | 02:40 PM
Pauliejr's Avatar
the only problem with black is it wont show as much in the blacl trunk.......
anyone interested in specs or pictures?
Old Oct 21, 2006 | 02:41 PM
truplay8's Avatar
THE BATMOBILE
def silver
Old Oct 21, 2006 | 04:13 PM
Pauliejr's Avatar
No One asked For specifications yet but here they are anyway
PICTURES BELOW
Im Puttin
2 Ground Pounder Subs which are:
1200-Watts Maxx
600-Watts RMS Power
1 Ground Pounder 1100 w Amp
1 / 2 - Channel Sound Quality Amplifier
275W x 2-Ch @ 4-Ohms or
550W x 2-Ch @ 2-Ohms or
1100W x 1-Ch @ 4-Ohms Dynamic Music Watts
1 Ground Pounder 880w Amp
880W Ultra-Clean A/B Class
2 / 3 / 4-Channel Sound Quality Amplifier
110W x 4-Ch @ 4-Ohms or
220W x 4-Ch @ 2-Ohms or
440W x 2-Ch @ 4-Ohms Dynamic Music Watts
Interiors
4-Hifonics Atlas 6.5'' 125w rms / 250w maxx
Attached Thumbnails My Custom System    --Fiberglass---pic_gp_subs_pair.jpg   My Custom System    --Fiberglass---pic_spkr_atlas_680.gif.jpg   My Custom System    --Fiberglass---pic_gp_amps_1100.2.jpg   My Custom System    --Fiberglass---pic_gp_amps_880.4.jpg   My Custom System    --Fiberglass---gpamp_ani.gif
Old Oct 21, 2006 | 06:08 PM
redlude97's Avatar
PICTURES BELOW
Im Puttin
1200-Watts Maxx
600-Watts RMS Power
Interiors
So what do those amps put down for RMS? dynamics power doesn't mean anything
Old Oct 21, 2006 | 06:34 PM
Pauliejr's Avatar
One putts out 880w and the other is 1100w
Old Oct 22, 2006 | 03:57 AM
digital1986's Avatar
whatever the watts max are the RMS is half
Old Oct 22, 2006 | 11:36 AM
superdude's Avatar
thats not the truth. It really depends on electrical system. if you dont give each amp proper wiring and if the voltage drops, RMS will go down.
You cant base on amp on wattage alone
Old Oct 22, 2006 | 12:28 PM
redlude97's Avatar
Assuming best case scenario, you are only feeding those amps 275watts RMS, which seems a little on the low side, I think you either need to pick up another one of those 1100w amps, or get a better amp that puts down close to 1000w rms total
Old Oct 22, 2006 | 12:29 PM
superdude's Avatar
and a better amp in general, crunch amps are rated very high and clip.
Old Oct 22, 2006 | 04:14 PM
footmasta's Avatar
If both of those subs run 600 watts RMS I would go with atleast 1200watts RMS for them. Or get one sub and get a really good amp for it.
Alot of people don't realize that under powering subs is what blows them
Old Oct 22, 2006 | 04:24 PM
redlude97's Avatar
This is false. a sub gets blown when the amp powering it supplies more power than it can thermally dissipate. This usually occurs when a clipped signal is sent to a sub since a clipped signal is almost a square shaped, and will only lead to failure if the power output of the clipped signal results in more power than the sub can dissipate. You could run a 600w rms sub all day with a 100w rms amp at full gain distorted to all hell and still not blow the sub, but if you sent the same distorted signal from a 600w rms amp, it would definately blow
