DIY: Moding & Hacking your avic - REVERT AVIC back to Lower SW Ver.
Old Oct 24, 2006 | 01:12 PM
speedgeek's Avatar
Smile DIY: Moding & Hacking your avic - REVERT AVIC back to Lower SW Ver.
http://www.the12volt.com/installbay/...531&pn=0&tpn=9
or (copied from link)
This works on my AVIC N1 so I believe that the buttons that I am about to speak of using will also map over to all other units too.
Unit should be on and do not interrupt power until flashing has completed or you will be sending unit back to manufacturer for Jtagging. Unit will indicate when reflashing has completed.
I am not to be held liable for any damage to your unit and any of this information put forward is strictly for sheer enjoyment.
1. Eject any DVD's /CD's from unit
2. HOLD EJECT and at same time press the reset button with toothpick or other tiny instrument.
3. Keep holding the EJECT button as screen will cycle in and out. As screen comes back out, you can release the eject button.
4. If all of this has been done successfully up to this point, you should be staring at a screen that says in black and white "Press Reset Button" DO NOT press the reset button or you will be doing steps 1-3 again.
5. Now this is the time to enter the code sush1a has provided us. While staring at the monitor screen with the message on it, now use the Joystick to enter the following movements:
UP RIGHT UP RIGHT DOWN RIGHT DOWN RIGHT PRESS IN JOYSTICK and you should be rewarded with a screen that has some red in it and dissappears quickly and is replace by one that looks like this:
Use the Joystick and press it to the right once to navigate to next screen:
Choose option #6 by pressing down on the joystick until option #6 is highlighted.
Now press the joystick in to select this option.
You should see this screen:
For most of us, we will be choosing #1, #2 and #3 and obviously not at the same time.
Next we need to insert the NAV DVD that we want to force flash from. Make sure it is clean and the right version!
Now it will prompt you with a option of what drive to flash from. Logic dictates that we will be choosing the DVD ROM Drive.
If you try to start the flash by pressing in the joystick, you are wrong. As sush1a indicated, you can use the /FUNCTION/ button on your remote to initiate this OR as with my N1, You can press the green POS button (middle button on bottom of folding screen).
Watch the data % and do not interrupt power until reflashing indicates complete! My unit stopped responding after completing task, so you may need to re-enter service mode again and again to reflash all portions of the OS on your N1/N2. I cycled power and Ba BOOM! it reset, re-initialized and pow! Not even a waypoint or the calibration file was touched.
Old Oct 24, 2006 | 10:59 PM
GreenGoblin's Avatar
The goblin resurrection
why would you need to any of this sorry if this is a dumb question but what are you tring to accomplish
Old Oct 24, 2006 | 11:08 PM
Glex25's Avatar
Administrator
Those that have upgraded their GPS Nav Disk to the newer version have found that they can no longer view DVD Video while driving.
Therefore need to reflash to the older programming so they can get video back while driving.
Old Oct 25, 2006 | 10:38 AM
would this work on an 04 with out the tv to go box
Old Oct 25, 2006 | 02:10 PM
speedgeek's Avatar
It's for the Pioneer AVIC headunits
Old Oct 25, 2006 | 07:31 PM
ok im sorry
Hasanbaloch
Feb 29, 2024 08:45 PM
Ednica87
Sep 5, 2015 02:59 AM
mann1961
Aug 9, 2015 08:44 AM
apintojr
Jul 23, 2015 10:52 AM
