Subs w/ Amp Install
Old Oct 29, 2003 | 10:17 PM
badboyg200's Avatar
Subs w/ Amp Install
QUICK QUESTION: I got offered after constant bickering two JL AUDIO W3 's VERSION 2 with an alphasonik 1000 watt amp with double box and install.. for $450 ... I feel its a pretty good deal... I have an appointment tomorrow at 1:30 for the install... but I need your feedback first ... do you think its a good deal?? FEEDBACK WOULD BE AWESOME! THANKS
< PICS OF SUBS>
PRODUCT INFO
Nominal Diameter: 10 inches (250 mm)
Continuous Power Handling: 300 Watts
Voice Coil: 2.25" diameter, 4-layer, Kapton former
Available Configurations: Dual 6 ohm
Xmax (one-way, linear): 0.51"-0.58" (13.0-14.7 mm)
Sealed Enclosure Range: 0.60-0.90 cu.ft.
(17.0-25.5 liters)
Ported Enclosure Range: 1.00-1.50 cu.ft. (28.3-42.0 liters)
VRC™ Technology: YES
Elevated Frame Technology: YES
In addition to JL Audio’s patented VRC™
technology, the 10W3v2 Feature 20% more power handling than the original W3. The W3v2 subwoofer drivers deliver exceptional tonal balance and impressive output in compact enclosures and are ideal for moderate to high power applications.
BaDbOy - "bLaCk BeAuTy"
http://www.cardomain.com/member_page...page_id=321439
Old Oct 30, 2003 | 01:56 AM
limeg35's Avatar
Re: Subs w/ Amp Install
hello: the retail on 10w3v2 is bout 219, not sure which alphasonik' amp you referring to, but the pma2500 is 500x2 and retail for 680, now i am not sure how you can get those for 450 with box installed! but if you did, make sure they dont use the dual 6 ohm subs, unless you use three of them, do you know if the alphasonik's take line level inputs? cause the G's radio dont have RCA out, so you would need an inline converter(soundgate, PAC, direct), and it could cause BIG problem for the installer, if they have no exprience with an G before...you cant really go wrong with JL's, just need to watch the install process closely...good luck...s.w.
03 coupe 5AT DG/G premium,performance
Old Oct 30, 2003 | 05:25 AM
g35audioman's Avatar
seems like a good deal depending on which amp it exactly is. Make sure you use dual 4 ohm subs for a 4 ohm mono load or dual 2 ohm subs for a 2 ohm mono load. It should sound pretty good.
g.spot
May 9, 2016 10:54 PM
zoop425
Mar 29, 2016 05:51 PM
JustinMKN1
Sep 18, 2015 03:40 PM
Frostbite91
Aug 2, 2015 04:59 PM
Thunderaan
Jul 22, 2015 07:40 PM
