JL Audio
Old Nov 9, 2006 | 01:21 PM
ttrank's Avatar
Grocery getter
I'm always up for some clean audio pics. Get them posted!
Old Nov 9, 2006 | 02:01 PM
steve465's Avatar
Old Nov 9, 2006 | 02:11 PM
steve465's Avatar
This is nothing outlandish but it is exactly what I wanted. I've heard many systems and I couldn't be happier. I lost about 1.5" in the depth of the trunk but I don't use it much any way. The Cleansweep definately made a big difference with the base HU. It has a switch to let you hear with and without processing. I highly recommend it, at least for base HU's.
Base HU, Cleansweep, JL650CSi front, JL650CXi rear fill, JL 10W6V2 sub. Fronts are pushed by a JL 300/4 and the sub with a 500/1 with a remote base control.
Also, the Cleensweep has one set of Aux inputs. Works great for sat. radio or mp3. Far superior to FM hookup!
Old Nov 10, 2006 | 10:39 AM
bb996+r1's Avatar
The cleansweep has pros and cons. Mostly cons.
Con's ----No sub level control so you have to have two *****.
When used correctly you loose steering wheel controls.
Only 4 pre amp outputs.
I would recommend the lc6i or lc8 by audiocontrol.
Old Nov 10, 2006 | 02:27 PM
steve465's Avatar
bb, while I do have two ***** (volume and remote base), I didn't lose any of the steering wheel controls. It is a pain to always check to make sure that the HU volume is set to the calibrated level. Other than that, I have no complaints.
On the flip side, I can leave the Cleansweep volume control at a pre-set level and use the steering volume control. I rarely do that because it is slow changing from 3/4 volume to low if I get a call or something.
Sure there are other choices out there and some may be better than JL. But, I'm a happy camper and the only one I have to please is me.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
