one more simple little install for you guys :)
Old Nov 30, 2006 | 07:16 PM
16psibrick's Avatar
jsut gone done with another IS350, not as fancy as the one i did before, just a clean and neat little one
goals:
1. great sound quality while maintaining stock HU
2. relatively stealthy look but maintaining full access to the spare tire
The front stage is a pair of DLS ultimate UR36i 3 way components, the 6.5" midbass is sealed in the door via a pair of enclosure cups, and the mid and tweet are in custom built suede trimmed kick panels. the doors are also dampened
annoying to do but the rear deck stock subwoofer was removed to get better bass into the cab in
the DLS remote bass control module resides int he stock astray location
moving on the trunk, here is the normal view, as you can see, nothing fancy, just a fake wall carpeted
pop out the center grille, unlatch and pull out the bottom though, a 10w6 and a DLS reference RA50 5 channel amp show through red suede just to give a bit of uniqueness to the install
and here you see the spare tire is fully accessible
and one more behind the scene picture of the HUGE amounts of wiring behind the amp rack, tied up neatly and bundled so the drawer would slide in and out without a problem
overall, sounds quite good with the stock headunit, and in the IS, the front stage yields an extremely solid center image and dash high stage
Old Nov 30, 2006 | 08:05 PM
dovla's Avatar
Nice. Does amp drawer need to be open for cooling?
Please tell us about these enclosure cups - would G35 coupe need them? Thanks
Old Nov 30, 2006 | 08:11 PM
16psibrick's Avatar
sorry, last pic wasnt showing, there are two push pull fans on the back of the amp rack
i used the cups a lot of times on Gs with 3 way set ups helps a lot with midbass response
b
Old Nov 30, 2006 | 08:42 PM
Down_Shift's Avatar
Are they durable enough for the careless people that would kick those speakers?
Old Nov 30, 2006 | 09:03 PM
16psibrick's Avatar
yup i have built well over 100 pairs, never had one destroyed, ever you cant kick through solid fiberglass, and the sepaker and tweetr grilles are metal and hard plastic.
the only way you can destroy kicks is if you take a screw driver and deliberately jab into the speakres very hard
Old Nov 30, 2006 | 09:33 PM
erdog's Avatar
That looks really nice.
What are the cups made out of?
Are there 2 speakers in the door and 2 in the kicks so 4 speakers on each front side?
Old Nov 30, 2006 | 09:49 PM
KJG35's Avatar
nice
wow the trunk on the IS is very clean and still has lots of space. How did you manage that. i know in our Gs a W7 takes up like half the trunk, but then again is it beacuse we have smaller trunks to wrk with.
Old Nov 30, 2006 | 11:05 PM
16psibrick's Avatar
thats a w6, so a bit shallowre, and by putting hte amp below the sub it saves a bit more space
no its a 3 way upfront, one in the door, the stock midrange is NOT hooked up
b
Old Nov 30, 2006 | 11:16 PM
digital1986's Avatar
very pimp, I will be using those doors as a guide on what to put my edead on
Old Nov 30, 2006 | 11:41 PM
GreenGoblin's Avatar
The goblin resurrection
looks great only thing that bugs me is the latched for the drawer
Old Dec 1, 2006 | 12:51 AM
16psibrick's Avatar
i know what you mean, but i didnt have too many choices you have any other ideas?
Old Dec 1, 2006 | 01:11 AM
ttrank's Avatar
Grocery getter
Not a fan of the kicks, they just look too out of place.
Trunk came out very nice!
Old Dec 1, 2006 | 09:01 AM
35bills's Avatar
Do you have any pics the kick pannels mounted in a sedan? (Would it look the same as the coupe?)
Old Dec 1, 2006 | 10:01 AM
Sponger's Avatar
6MT Brembo Coupe
16psi, I enjoy your work. Good stuff.
Old Dec 1, 2006 | 10:53 AM
16psibrick's Avatar
3 way kicks in a G, regardless of sedan or coupe, would look MUCH more recessed than in the IS350, keep in mind the IS does NOT have a plastic stock kick piece, and has the emergency brake there so the kick panel has to be where it is
anyway, here is hwat 3 way kicks in a G pretty much looks like:
