Aftermarket Headunit Concern
Old Dec 2, 2006 | 10:02 PM
nalinc23's Avatar
If i get a double din dvd headunit is there any way to retain......????
-Steering Wheel Controls
-Factory Sirius Satellite Radio Capability
Thank you much!
nate
Old Dec 3, 2006 | 09:41 PM
DaygoG35's Avatar
If you get an aftermarket stereo, you can retain use of your steering wheel controls with a PAC-SWIX. This is a universal adapter that uses infrared light to control your aftermarket stereo from steering wheel. You would have to program the buttons. Most car installers are familiar with this product and can install it for you. I think their are PAC adapters that are specifically for particular aftermarket stereos that are hardwired. Do a search for PAC.
As for Sirius Satellite, you should be able to keep your antenna if you stay with Sirius. Check with your aftermarket stereo for satellite service that they support.
Old Dec 4, 2006 | 04:48 PM
nyclifeg's Avatar
You can use the antenna but not the reciever, you will need to get the reciever that goes with your double din and connect the antenna and switch radio ID number.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
