Safe to use 10 gauge wiring kit or stick with 4 gauge wiring kit?
Old Dec 10, 2006 | 02:13 PM
emtguy05's Avatar
I found for 10 bucks a 10 gauge wiring kit. Would it be safe to use that to supply my JL 12w6v2 and JL 500/1 amp to my stock bose radio? Or should i use the 4 gauge amp wiring kit?
Old Dec 10, 2006 | 02:19 PM
hai109's Avatar
4 gauge....
Old Dec 10, 2006 | 02:20 PM
Meatshackle's Avatar
Deep Sea Moderator
JL recommends a minimum of 8 gauge for the 500/1.
If you're running your power from the battery I'd recommend the 4 because of the distance. 8 gauge is ok for a shorter distance with 500 watts. I've got 4 gauge from the battery going to a fused distribution block so I can run 8 for just a few feet to my amps.
Old Dec 10, 2006 | 02:37 PM
emtguy05's Avatar
so can i just use the 8 gauge? the only 4 gauge i can find is http://www.bestbuy.com/site/olspage....cat30100050007
for like 800W or more. i dotn really need that many i'm only running one sub with the 500/1 amp
Old Dec 10, 2006 | 06:21 PM
redlude97's Avatar
Buy the 4 guage kit from here http://www.knukonceptz.com/
8 guage is going to be too small for a 500/1.
Old Dec 10, 2006 | 09:03 PM
Deep Sea Moderator
www.the12volt.com has a good chart for power cable size.
For 400 watts 8 gauge is good for 8 feet, 600 watts 8 gauge is good for 4 feet.
Get the 4 gauge and make sure you also use 4 gauge for your ground.
Old Dec 10, 2006 | 10:39 PM
4 Door Skyline's Avatar
definately go 4 Gauge!! its always best to err on the side of safety
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
whattf
Sep 1, 2015 07:42 PM
TWASkyliner
Aug 1, 2015 11:43 AM
