tvandnav2go non pnp wiring on 06 Coupe
Howdy guys,
I am trying to install a non plug and play TvAndNavToGo. I am having trouble identifying which wires I should be cutting and connecting to.
Does anyone have a wiring diagram of what wires go where? The sheet of paper I got with the device is not specific to the 06 G35 coupe.
A Couple other questions.
- Where should I tie all the "ground" wires to?
- What kind of connectors are you using? Just regular crimp style?
- For the 12v power, did you just cut back the protective coating on the cigarette lighter wire and use a "T" wire tap?
Thanks Guys. I have scoured the forum and can't find any non pnp help. Most posts just say to call Dom... I think this info should be in a thread!
Thanks again.
Jason
Thanks again.
Jason
Hi Mammalian04
Hope all is well.
The instuctions you got are specific to the 06 G35 coupe. Please call me and I will explain them to you.
1) You will tie all grounds to the body of the car.
2) You will Soilder and tape and RGB conections.
3) Yes you can T Tap the ligher.
Thanks Dominic www.TVandNav2Go.com
Hope all is well.
Originally Posted by Mammalian04
Howdy guys,
Thanks again.
Jason
Thanks again.
Jason
Karran Dhanroop
Aug 2, 2015 08:22 PM
Thunderaan
Jul 22, 2015 07:40 PM
