back seat removal
Old Jan 24, 2007 | 03:14 PM
rooster's Avatar
back seat removal
i have an 04 sedan and i'm having a hard time removing the backseat. i took out the 2 bolts. i'm pulling in every direction but it just won't budge. any suggestions?
Old Jan 24, 2007 | 04:06 PM
Infinite_R's Avatar
Yaaaah Yaah Trick!!
Thumbs up
I actually have my entire back seat and panels out right now because I'm about to do my system install. If you search back seat removal in the DIY you can find it. What part are you trying to remove. For the bottom just grab at the center of both seats and pull up. They are clipped in the front, but if you pull hard enough they'll pop out w/ no damage, then for the back just remove the 4 bolts on the lower hinge and disconnect the emergency trunk release wire and Presto!!
Old Jan 24, 2007 | 04:40 PM
tkman00's Avatar
i think it's the two in the middle behind the armrest and then the two on each side
next time remember that searching does wonders
Old Jan 24, 2007 | 04:54 PM
rooster's Avatar
yess! it's those 2 bolts behind the armrest that i couldnt see
thanks for the help guys.
Old Jan 24, 2007 | 05:36 PM
Infinite_R's Avatar
Yaaaah Yaah Trick!!
My mistake!! I didn't realize you were referring to the sedan.
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
brian_z
Jul 20, 2015 01:30 AM
