aftermarket amp install?
Old Nov 26, 2003 | 10:01 PM
aenokea's Avatar
I plan to add a sub to my coupe and would like to know where you guys mounted the amp. Would it be safe to mount the amp on top of the Bose amp? The Xtant amp I plan to install would barely fit. I was thinking of under the seats but theres not much room there too. Any info would be appreciated.
Old Nov 26, 2003 | 11:15 PM
d3g's Avatar
d3g
Re: aftermarket amp install?
I tried installing my amp in the location of the bose amp but it gets too hot! My amp kept shutting off. I had to move it in the trunk. Its currently mounted on my 12" box but im planning on getting a custom box made that will allow for 2 subs and 2 amps mounted in/on it. Couldnt think of another place to mount the amps. I saw some guy's post where he pulled out the spare tire, installed a sub and amp in that spot, and used clear plex glass so you could see the amp. You lose your spare tire tho.
www.corevoltage.com
Stillen Box | Fallsgate Amp | Projection Fogs
Old Nov 26, 2003 | 11:37 PM
JAG35CP's Avatar
Take out the bose amp.
Old Nov 27, 2003 | 02:29 PM
areddy14's Avatar
How much was that setup JAG35CP, and what do you got?
cb/graphite g35c - fully loaded
Old Nov 27, 2003 | 06:38 PM
aenokea's Avatar
I plan to keep the system basically stock so I need to keep the Bose amp. Has anyone done the installation and been able to keep the Bose amp there? Im going for a "stealth" installation so I dont want the amp in the open. Any other locations that I should look at?
hdmark
Apr 29, 2019 04:31 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
Frostbite91
Aug 12, 2015 05:16 PM
Frostbite91
Aug 2, 2015 04:59 PM
Thunderaan
Jul 22, 2015 07:40 PM
