04.. dd bracket
Old Mar 9, 2007 | 10:04 PM
g'dup13's Avatar
04.. dd bracket
k ive been searching on the forums b4 u guys start bashing me n telling me to use that feature...
to all the 03-04 dd kit owners do u need that dd bracket? or can i use the existing one in the car right now? i dont have navi....
Old Mar 9, 2007 | 10:24 PM
Infinite_R's Avatar
Yaaaah Yaah Trick!!
You don't need it, but I bought it off another member so I could have two set ups ready. Aftermarket and Factory so all I need to switch back is the pocket.
Old Mar 9, 2007 | 11:20 PM
DHCrocks's Avatar
not needed. reuse the stock bracket. not sure if this applys to all decks but mine (Clarion MAX675VD) stuck out about 1/2" to get it to sit flush I had to redrill the mounting holes (4 on each side) to push the deck in so it's sits more flush. I hear with the DD bracket no drilling is required so if you're lazy it might be for you.
Old Mar 10, 2007 | 08:22 AM
g'dup13's Avatar
thanx for the reply.. i wont b doing the install so it doesnt matter..lol
thank you.... was thinking of doing the same thing....thanx again...
Old Mar 10, 2007 | 01:49 PM
seddon's Avatar
Hector if you want the bracket you can have it. Dammit do the install yourself stop being lazy. Hit me up when you gat a chance.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
dcsbh1
Oct 1, 2015 03:15 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
