View Poll Results: Like the Cubby Outlet?
LOVE IT!
31.71%
It's cool... prolly wont attempt to install one
68.29%
Voters: 41. You may not vote on this poll
My Nuvi Install with custom Power Outlet in cubby..pix
Old Mar 11, 2007 | 11:10 PM
filanj's Avatar
Originally Posted by stpdevil
Not trying to jack your thread, but anyone who wants to do this should keep in mind that the garmin sp26xx and sp27xx series fit perfectly in our cubby holes w/ no modification.
No worries. The Nuvi fits perfectly in there. I only modified it because I didn't want medusa's head coming out of the cubby hole as per your setup
Old Mar 12, 2007 | 09:22 AM
joedaddy1's Avatar
question:
would the Nuvi 650/660 (i think they are called) fit there better since they are wide screen? i might be wrong though...
I have the OEM Nav in my car, but also have a Garmin C330 @ home. and i hate to say it, but i like the Garmin better, minus the bigger screen on the OEM...
Old Mar 12, 2007 | 12:05 PM
omasica's Avatar
There is no way to make it fold into the box? Thats what I really wanted to do.
Old Mar 12, 2007 | 01:13 PM
filanj's Avatar
Originally Posted by joedaddy1
question:
What do you mean Nuvi 660? That is the one I installed; the 660.
Garmin seems to be (one of) the top leaders in Navigation. This is my fourth partable garmin and if one and two weren't up to par, then three and four would not have been purchased.
Old Mar 12, 2007 | 01:20 PM
filanj's Avatar
I haven't dabbled with any sort of folding in techniques yet. I would love for it to do so, but the way that the mounting arm rotates and moves would require a much lower mounting stance. I'm on vacation till Thursday night, so the G is back in Jersey. When I get back I will attempt to improve the base mount even more (if applicable).
Old May 1, 2007 | 10:48 AM
Steel Blue's Avatar
Nice job with the install. This thread is going to help me quite a bit with my own project.
Old May 1, 2007 | 10:53 AM
filanj's Avatar
Thanks. Good to hear that. Good luck on your install
Old May 16, 2007 | 07:41 AM
jimmyc13's Avatar
Nice job, but seems like an awful lot of work. I accomplished pretty much the same thing, but don't have an extra adapter outlet...my '04 already has 3 of them up front, so don't need a 4th.
Here's what I did, and it only took 15 minutes:
I epoxy'd the metal disc to the back of the front face of the cubby hole. Then I hardwired the unit using a different power adapter than the one that came with the unit. I drilled a 1/4" hole in the back left side of the cubby, and then attached the spliced end of the wire on the end of a thin metal coat hanger & quite easily was able to fish the wire down the hole & came out near the gas pedal (out of the way) and snuck the wires under the steering column and above the fuse box, down into the box. Then I grounded the black wire & stuck the red/hot wire into the fuse slot for my power adapter.
Old May 16, 2007 | 10:08 AM
Steel Blue's Avatar
Nice clean install, but are you able to close the GPS unit into the cubby when not in use?
Old May 16, 2007 | 10:28 AM
DocJohn's Avatar
I have a NUVI 660 too and your installation looks great!
Can you please post some pics of the mounting inside the cubby?
Thanks
Old May 16, 2007 | 10:47 AM
Conscons's Avatar
Great work`~ looks awsome
Old May 16, 2007 | 10:50 AM
b00stedjustin's Avatar
Reeaaalllly nice install
Old May 16, 2007 | 02:58 PM
jimmyc13's Avatar
Thanks
Thanks!
Go to thread #31 for more detailed picts.... https://g35driver.com/forums/audio-video-electronics/120929-garmin-nuvi-660-navigation-unit.html
Here are some more options on how to mount it:
https://g35driver.com/forums/showthr...ht=garmin+nuvi
Old May 16, 2007 | 03:00 PM
jimmyc13's Avatar
What do you mean "close the GPS into the cubby"? You cannot fit the Navi unit & the mount inside the cubby (actually have never tried), but you can close the cubby (AFTER removing suction cup from the disc). The disc does not interfere with closing the cubby. Make sense?
Old May 16, 2007 | 03:26 PM
  #30
willthethrill's Avatar
looks great man! good choice with the nuvi.
