Wiring Help!!!!!!!!!!!!
Old Mar 19, 2007 | 05:40 PM
jayjayg35's Avatar
ok im getting a little confused doing a search
so can someone help me with what i need for wiring for my 03 coupe with BOSE?
do i need the PAC-ROEM-NIS2 and the speaker wire harness?
what else do i need?
oh this is for my Pioneer AVIC-D1
Old Mar 19, 2007 | 06:05 PM
Gilley's Avatar
What is your entire audio plan?
Are you going to use the AVIC-D1 with the Bose amp and speakers? I'd avoid using the Bose amp.
Old Mar 19, 2007 | 06:10 PM
Hi-TechG35's Avatar
I just did my system and left the stock head unit but like Gilley said eliminate the Bose system completely if possible. If you are tryin to keep the car as stock as possible you will need the PAC steering wheel controls and the radio harness as well if you are not changing door/deck speakers you will be all set.
Old Mar 19, 2007 | 07:54 PM
jayjayg35's Avatar
i just wanted to keep the original speakers and bose factory amp . i was just looking to install the avic-d1 for the navigation purposes and have the cd rolled into....im not looking to have a big system
so what sholud i do
bypass the amp?
and if so how do i do that?
thanks in advance
Old Mar 20, 2007 | 05:47 AM
jayjayg35's Avatar
ok so like i said i want to just put in the AVIC-D1 and leave everything else
STOCK
so do i ned the PAC AOEM-NIS2 unit? and scoche wiring harness?
has anyone ever used the Metra harness code 70-7551? here's the link
http://www.metraonline.com/product_l...l=G35&type=ALL
click on the pic with the double harness.
i went to the audio shop and they told me that this has the wire harness in it as well as amp inergration it has 2 rca plugs on each harness.i believe the rca plugs plug into the factory amp...which is where???
since i've never seen or read about this product i am a little hesitant on using it.
i dont want to install it and have hissing noises and general noise in my speakers
this will clear up alot for me since this is the whats confusing me the most
Old Mar 20, 2007 | 10:01 AM
Gilley's Avatar
To do the DD swap, you need the JDM trim piece, the JDM A/C controller, Nissan antenna adapter, and the Nissan wiring harness adapter (for power and speakers.) You will also need an appropriate PAC steering wheel adapter for Pioneers.
The parts listed on the page of that link will work (http://www.metraonline.com/product_l...=G35&type=ALL), except the next to last (70-7551) because the Bose amp does not use RCA plugs. It uses automotive connectors. BTW, the amp is located to the left of the spare tire.
If I were you, I would use the Pioneer's internal amp power, run wires all the way to the trunk, and connect into the outpur wires from the Bose amp to the speakers. The Bose amp has funky EQ curves built into it and isn't a powerhouse at all. The Pioneer outputs 22 watts x 4 continuous.
Better yet would be to add a small multichannel amp in place of the Bose amp, then you could use the wiring harness with the RCA connections.
The following info will help your installer connect to the correct Bose wires in the trunk.
BOSE WIRING COLORS AND SPEAKER SIZES
Factory speaker harness wiring colors
Front Right + Gray/Silver
Front Right - Yellow/Silver
Front Left + Green/Silver
Front Left - Red/Silver
Rear Door Right + Brown/Silver
Rear Door Right - Black/Silver
Rear Door Left + Green/Yellow
Rear Door Left - Black/Yellow
Rear Deck Right + Blue/Red
Rear Deck Right - Blue/White
Rear Deck Left + Blue/Yellow
Rear Deck Left - White/Green
Head unit output colors
The (+) are all on the same side of the connector.
Head Output Front Right + Orange/Blue
Head Output Front Right - White/Blue
Head Output Front Left + White
Head Output Front Left - Orange
Head Output Rear Right + Blue
Head Output Rear Right - Pink
Head Output Rear Left + Teal
Head Output Rear Left - Purple
Remote Wire Light Blue/ Silver
Old Mar 20, 2007 | 04:07 PM
jayjayg35's Avatar
wow that was a super help
thank you
at least if i run the wires to the back i can change things later on
Old Mar 20, 2007 | 04:48 PM
Gilley's Avatar
You are welcome.
Are you doing the install yourself? Do you have the JDM finisher and AC controller?
Old Mar 20, 2007 | 05:28 PM
jayjayg35's Avatar
they re on they're wy as we speak ....yes i'm going to do it with the help of some friends who have had the pioneer navi series since they first cam out , they know all about the deck
my part is to find out everything i need to know about the car.
the anntenna adpator ...does it spilt into 2 or is just one wire cause the guy at the shop didnt know exactly which one it was his reference book was giving him a double answer ..
one more question .....i know there are certain wires that need to be hook up so everything on the deck works ...i think something like VSS wire? its for the car diagnostic on the pioneer i believe .
Old Mar 20, 2007 | 08:36 PM
Gilley's Avatar
I don't know anything about the Pioneer wiring.
For the antenna adapter, you need the aftermarket radio to diversity antenna adapter, PN 40-NI10 on that site.
Old Mar 20, 2007 | 10:07 PM
jayjayg35's Avatar
ok great so i bought the wrong antenna
thanks gilley youve helped out alot
so the amp is in the spare tire area or your just saying its on the one side of the trunk?
Old Mar 21, 2007 | 09:59 AM
Gilley's Avatar
we have the diversity antenna in the car, so you need the adapter to go from the diversity antenna to an aftermarket radio.
To find the Bose amp, take out the trunk carpet to get to the spare tire. To the left of the spare tire is a plastic piece. The Bose amp is under the plastic piece, bolted upside down to a metal bracket.
I removed the Bose amp and mounted my JL amp on top of the Bose metal bracket. I had to trim the plastic piece to fit, but if you get a smaller amp, it may work without trimming.
Old Mar 21, 2007 | 05:43 PM
jayjayg35's Avatar
Thumbs up
Nice !!
good idea gilley thanks again!!!
im thinking about buying an amp now from a friend the run the speakers so everything looks good for now!
ill message you if i need more help gilley thanks a ton!
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
