Lights flickering
Old Jan 12, 2026 | 01:36 AM
Someusername's Avatar
Lights flickering
This could potentially be a bad battery but I am going to replace it soon though, but when I turn the key to the run position but don't start it the Door lights flicker and sometimes the high beams come on. I can hear an audible clicking noise which I am going to guess is the relays flicking. I am wondering if anyone else has run into something similar and what fixed it.
Old Jan 18, 2026 | 08:11 AM
shurur's Avatar
2003 G35 Coupe
Just recently.
bad alternator dropped the Battery down until it stalled.
Head lights were flickering.
Weird things happen with low battery.
I didn't measure the battery voltage when the car stalled, but when I charged it, the charger read 12V and 5% unloaded. The battery was a new battery though, so probably just a charge issue.
I charged the battery to 75% before hooking into the car with new alternator.
Battery charging was 13.8+ V
bmw and audi have troubles at 11.7V. I suspect the same for G35.
Old May 22, 2026 | 08:06 PM
RichardRichards's Avatar
Tämä kuulostaa hyvin tyypilliseltä heikon akun tai huonon maadoituksen oireelta. Kun virrat kytketään asentoon “run” ilman käynnistystä, järjestelmä ei saa tasaista jännitettä, jolloin releet voivat naksahtaa ja valot vilkkua tai käyttäytyä oudosti.Jos akku on vanha tai jännite putoaa nopeasti kuormassa, elektroniset moduulit alkavat “seota” juuri tuolla tavalla. Myös löysä tai hapettunut akkunapa tai runkomaadoitus voi aiheuttaa saman ilmiön, joten ne kannattaa tarkistaa ennen akun vaihtoa.
Samuel.N
V36 Interior, Exterior & Lighting
Jan 11, 2015 05:37 PM
DenZeL KnighT
Feb 8, 2010 04:21 PM
thehin
Lighting
Jul 9, 2007 12:33 PM
JC-RH
Apr 12, 2007 01:00 AM
