Amp possibly burned out?
Old Mar 29, 2007 | 10:03 PM
G'duprideR6's Avatar
JL Audio 500/1 Amp possibly burned out?
I recently removed my sub and 4080 box out of my car due to the sub blowing. What I forgot to do was cover up the negative and positive speaker wire from the amp to sub. Today I was grabbing something from the trunk and discovered that the 2 wires fused together and it is slightly blacked on the wires because of them being burned out together. I also touched the amp and it was SUPER HOT. Now what im wondering is if I possibly damaged the amp. It's a JL Audio 500/1. After I wrapped the wires up in electrical tape, i turned on the ignition and the amp still shows a green light like it's on. Does anyone know if it should still be okay? Thanks
Old Mar 30, 2007 | 05:28 AM
DHCrocks's Avatar
should be ok, the amp will just go into protection mode and shut down, after the short was removed everything should be back to normal.
Old Mar 30, 2007 | 01:09 PM
LjN_728's Avatar
^ +1...fuses would blow first
Old Mar 30, 2007 | 01:35 PM
hai109's Avatar
Most good amps has overload protection...You should be fine...
Old Mar 31, 2007 | 03:06 AM
thanks alot for the help!
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
