Double Din available for the 07 coupe????
Old May 2, 2007 | 06:05 PM
G35_7o2's Avatar
Just curious because i am planning on swapping my stock headunit for a after market. But i kan't find anything on an 07 double din. Is there anything available??? or is it completely different?? also i went to a well know audio store and asked if they could install the deck and the said the would have to look at it. is there any way they kan install it with out using a double din kit and the climate control thingy u have to buy????
Old May 2, 2007 | 06:13 PM
empfl's Avatar
I'm not so sure about the 07 deck but im pretty certain it's the same as the 06.
You could always custom make a box i suppose, but Double din is your safest bet. I think that the climate control is also needed. Not really sure why but.
GL w/ your install
Old May 2, 2007 | 11:03 PM
Gilley's Avatar
I'd have to do a visual check, but I thing the 07 DD kit is the same as the 05-06. you need the DD trim piece and the AC controller.
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
Frostbite91
Aug 2, 2015 04:59 PM
itztwinki3
Aug 1, 2015 12:58 AM
kd03g99
Jul 30, 2015 11:24 AM
