2005 G35X - Where is the Bose Amp?
Old May 3, 2007 | 06:12 PM
cmx1o1's Avatar
Hi,
Im having difficulty finding the Bose Amp, i have taken out the spare tire but i do not see the nut screw holding the cover down. Is the bose amp in a different location for the 2005 models? Im trying to install the factory ipod integration.
Thanks
Old May 4, 2007 | 08:34 AM
g35rcr's Avatar
there should be a plastic shroud on the left held in place with a 10mm bolt...its next to the fender liner
Old May 4, 2007 | 12:05 PM
cmx1o1's Avatar
i definately dont see the 10mm bolt, looks like everything is glued down. would it be possible it will be underneath the rubber lining?
Old May 4, 2007 | 11:01 PM
Gilley's Avatar
On the sedan, it's located in the trunk, under the rear window, on the right side, under the grey plastic cover.
Old May 5, 2007 | 05:44 PM
cmx1o1's Avatar
thanks for the tip, i found the amp but it seems like im not prewired for sat. i thought all 2005 were prewired or i just cant find the damn wire...
Old May 5, 2007 | 10:31 PM
Gilley's Avatar
You just haven't found the wire. All 2004 and up G's are prewired. It's taped up near the amp. See page 5, at the bottom, of the install instructions. http://static.zoovy.com/merchant/inf...te_Install.pdf
johnadlertech
Brakes
Aug 31, 2015 02:03 PM
Frostbite91
Aug 2, 2015 04:59 PM
kd03g99
Jul 30, 2015 11:24 AM
Thunderaan
Jul 22, 2015 07:40 PM
