10W6 or 10W3 for 4080
Old May 22, 2007 | 08:33 PM
Smooth_Imports's Avatar
Buying a sub this weekend debating between the 10w6 or the 10w3v2, Looking for opinions from people how have both or installers that have seen the results of either speakers in the 4080. Any input would be great.
Thank you.
Old May 22, 2007 | 08:42 PM
redlude97's Avatar
depends on the amp you are going to be running with it
Old May 22, 2007 | 08:44 PM
500/1 i was also looking at the polk sr104 that 4080 has recomended but i haven't heard much about them and would rather keep the amp and sub brand match because they are built to work with each other.
Old May 23, 2007 | 01:04 AM
wuyichao's Avatar
5001/1 with only 1 sub, go with 10w6v2
500/1 with dual subs, go with 2 10w3v2
Old May 23, 2007 | 01:08 AM
akachi's Avatar
having the same brand for sub and amp doesn't mean it works best w/ each other. u can mix and match. i have 10w6v2 and i was going to get 500/1 but it's a lil bit too weak for the sub. generally, you're suppose to overpower the sub by 100-200 watt. that's why i got the Alpine PDX 1.600 amp.
check out my thread attached with pics and videos
https://g35driver.com/forums/audio-video-electronics/155526-i-got-bass.html
Old May 23, 2007 | 06:41 AM
g35rcr's Avatar
the nice thing about jl's is that you can get them in multiple ohm setups...so worst case you can run a 2 ohm setup with your 4 ohm mono amp which would give you double the output
Old May 23, 2007 | 08:04 AM
Gilley's Avatar
JL amps have the same rated output regardless of whether your ohm load is 4 ohms or 2 ohms, so you won't get double the power from 2 ohms compared to 4 ohms. The Alpine PDX amps are like that too.
500/1 - 500 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
ZoominG35
Dec 6, 2015 03:11 PM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
ZoominG35
Oct 12, 2015 04:53 PM
mark5
Aug 20, 2004 10:04 AM
