? after removing the stock stereo
Old May 25, 2007 | 06:16 PM
SteveO28's Avatar
i have the 6 disc bose stereo and when i removed it i noticed it has 4 connections running to it. the wiring harness i was told to buy only has 2 different places to connect to. i think the other 2 simply run the disc changer but i was wondering if anyone can confirm this or if i have the wrong wiring harness. thanks
Old May 27, 2007 | 08:48 PM
allendoc's Avatar
Look at this thread I started.
https://g35driver.com/forums/audio-video-electronics/157269-i-have-working-nav-voice-bt-alpine-hu.html
It will show you what all four connectors are. If you didn't have Nav, Bluetooth or Steering Controls, they are useless to you. You can use the SAT connector as the other end is in the trunk.
Old May 27, 2007 | 11:38 PM
Gilley's Avatar
Two connectors are for the power and speakers - your adapters fit those - while one is sat wire and the other is the steering wheel control, which you may need if you got a PAC steering wheel interface module.
Old May 28, 2007 | 04:22 PM
SteveO28's Avatar
that was very helpful... thanks
EnCr1pt3d
Jul 8, 2019 02:48 PM
WillisFL
Dec 29, 2016 08:56 AM
skippyG
Jan 25, 2016 01:18 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
